MSD Box and carb
Old Apr 15, 2004 | 01:49 AM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
MSD Box and carb
Okay, so I know this isn't a completely orignial topic, but I haven't seen it before either... Where did all you folks with CARBS put your MSD box? I'm having a hell of a time finding a place, as I have two air snorkels in the way. But I just finished doing an A/C delete, so that should open up some space. Regardless, I'd like to see some pictures of boxes in carb'd engine bays, rather than TPI over and over and over. Hopefull I'm not alone in this?
Old Apr 15, 2004 | 03:00 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
https://www.thirdgen.org/techbb2/sho...hreadid=183568
Glance through that thread. I havent posted mine yet, but my box is where all that a/c blower motor crap and stuff was.
Old Apr 15, 2004 | 05:25 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
If your running a 6A over the booster it fits real clean
Old Apr 16, 2004 | 11:28 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
i should be putting my 6al in this weekend i was thinking of putting it in where the canister was on the driver side in the front laying flat but i dunno about water getting up in there cause i do drive it in the rain.
Old Apr 16, 2004 | 12:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I had mine mounted there for a while and never had trouble with it getting wet.
Old Apr 16, 2004 | 11:11 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
I got mine mounted on the passenger side of the consule right next to the radio so I have easy access to it. I don't have to pop the hood every time I want to change my rev limiter setting.
I then ran the wires and cable thru a small hole in the firewall to the distributer.
Old Apr 16, 2004 | 11:56 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
here is a pic of mine.
Old Apr 21, 2004 | 09:00 AM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Well i put my 6al in yesterday i mounted it where the canister was on the front driver side. looks pretty good there. i'll post pics when i can get a hold of a digi cam.
GTAman
Jul 3, 2024 07:29 PM
9192camaro
16
Feb 3, 2019 12:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
andy74
Sep 3, 2015 08:41 AM
overdriv
Aug 20, 2015 03:52 PM
