1984 Q-Jet CFM Rating?
Transmission: 4L80E/4L80E
"Rating" is a misnomer.
"Capability" is more like it. Some of them had the AV travel restricted so they would only flow in that range (mine wasn't). However, if you modify it so it will go full open per the tech article on the Board, it will flow at least 750 cfm.
It will flow more than a 305 can use, that much is for sure.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Some were restricted to about 600cfm, like 5-7 said, but an unrestricted one will flow 780cfm.
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Five7kid is right. 99% of all Q-Jets can be made to flow 750 cfm by allowing the A/V to open all the way, but there are a few Q-Jets with larger primary's that will go to 780 cfm. I would allow the A/V to open all the way because your eng. will determan if they will be pulled all the way open.
Auggie
Auggie
Originally posted by germ83
IS it a good idea to un restrick with a stock 305? What i am asking is, will it give me more power or will it just choke the motor? Stock 305
You got nothing to lose by un-restricting it though, even if it doesn't need it
Technically, the AV is opened by air flow (engine vacuum implies manifold vacuum), but that's the concept - the carb is as big as the engine needs it to be - up to about 750 cfm (and it's a rare 305 that can need 750 cfm).
The same "size" q-jet that feeds my 305 also fed my 396.
There you go again, trying to apply logic to factory design...
LT1Formula
Oct 8, 2015 08:34 PM
Dragonsys
Sep 25, 2015 03:51 PM
