Water down carb and CLUNK!!!!
Old Jun 4, 2004 | 05:44 PM
Hollis's Avatar
Car: 82 Camaro Z28 Indy 500 Pace Car, 98 Firebird
Transmission: TH200
Alot of water went down my carb and when I tried to start it and I just got one big clunk and no start. I tried again and it wouldn't turn over at all, after I waited a few mins and tried again it started but it was running like crap got out and walked around it and was checking it out and it had shot some oil out of each tail pipe. No more has came out but what exactly happened?
Old Jun 4, 2004 | 06:12 PM
Damon's Avatar
You hydro-locked the engine. Air is compressible. Water is not. Too much water getting in the engine and it will simply stop it from turning when the filled-up cylinder tries to come up on the compression stroke.
You need to change your oil/filter immediately (there's plenty of water in it now that it's leaked past the rings as it was sitting there unstarted). Change the plugs, too. They're probably plenty messed up as well.
Old Jun 4, 2004 | 06:30 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
And hydro-locking can do extreme damage. I've seen con-rods bent like a pretzel by this...no kidding. Even if a cylinder does not fire, the starter motor has enough toque to easily bend a rod. If even one cylinder fires there is enough force to bend a rod so badly that the piston will hit the crank. I've even seen cylinder walls split in half by hydo locking. It is a very,very bad thing
I would immedialtely do a compression test. If you find the that cylinder that had the water in it has a lower compresion than all of the others ( by more than 15lbs ) then it is likely that the rod is bent and the piston is sitting further down in the bore. If compression shows up weak on that cylinder, then pull the head and compare the deck height of that piston to the rest.
If that piston is sitting lower than the rest ( use a dial indicator if it's not obvious ) then it's time to pull the motor apart. A new rod and psiton will be the minimum that you should replace.
Old Jun 4, 2004 | 07:34 PM
Hollis's Avatar
Transmission: TH200
Well I just checked the oil and it seemed normal, ill check the plugs tomarrow.
Old Jun 4, 2004 | 08:49 PM
Parrydise7's Avatar
Don't just check the oil.... drain it! And change the oil filter while you are at it.
Old Jun 4, 2004 | 09:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What Damon & chickenman said...
I don't hold out high hopes for that motor. I've seen way too many of them with bent or twisted rods. That's usually what gives, is the rod.... especially weenie stock ones.
Definitely do change the oil and give it a try, you might have got lucky, maybe. But don't spend alot of money on the oil you put in it. If it runs but has a new vibration, don't expect it to live long.
Old Jun 4, 2004 | 09:10 PM
AM Racer's Avatar
Just curious .
How did you drown it before it was even running?
Old Jun 4, 2004 | 10:10 PM
Hollis's Avatar
Transmission: TH200
I am gonna change to oil too. How it happened, well I have the stock fiberglass hood that had the functional scoops but were sealed up by the previous owner to be nonfunctional cause he changed it from CFI to carb. But they leak like crazy and it ran right down through the open element cleaner.
Old Jun 4, 2004 | 11:14 PM
87Formula4bbl's Avatar
Car: '87 Formula
There you go. If it rained for a while, dripping right in there like that.....well.....good luck!
Old Jun 4, 2004 | 11:25 PM
ljnowell's Avatar
My parents have a 1998 pontiac bonneville, and these creatures are known for a faulty intake design on the 3.8. Well,when the intake gave out, it filled a couple cylinders full of water, and locked her up tight. After taking everything apart, replacing the intake and puting it all back together it was alright. Put about 40K more on it, and still running fine. Of course not everyone is that lucky.
Old Jun 4, 2004 | 11:47 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
and take that air cleaner you have on that engine remove it look at it really good then throw it away and go buy a good one because not only does it let water leak into your engine but if your carb backfires once that aircleaner will melt right down into your carb then youve got something else to rebuild or buy just a heads up i had one of those and it destroyed a carb so watch it
Old Jun 5, 2004 | 12:34 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Don't they like to catch on fire as well?? JUNK IT..
Old Jun 5, 2004 | 12:36 PM
THEGENERAL's Avatar
exactly
Old Jun 5, 2004 | 10:33 PM
Hollis's Avatar
Transmission: TH200
Well I changed the oil today and the plugs too even though they seemed normal. Theres no new engine noises and everything seems the same. But I have a new power stearing fluid leak ill have to check out. So you think I just got real lucky or will something pop up after awhile?
Old Jun 6, 2004 | 10:35 AM
THEGENERAL's Avatar
well its more of a game of chance at this point just dont get on it for a while act like its a new engine and you will find out how its gonna do for ya ......hopefully fine
Old Jun 7, 2004 | 12:10 AM
CanCritterRW's Avatar
Car: 91 gmc 4x4 tbi :O)
belive the stuff that came out tailpipe was carbon dislodged by the water...
Old Jun 7, 2004 | 05:19 PM
Marc 85Z28's Avatar
Very likely. At least you cleaned your chambers
Old Jun 7, 2004 | 06:39 PM
THEGENERAL's Avatar
id cleaned em well the only thing your missing is a brillo pad and them chambers would have been like new..lol...but glad it started okay for ya
Old Jun 7, 2004 | 07:39 PM
Hollis's Avatar
Transmission: TH200
I should be running a compresion test on thursday, hopfully it will be good. I have no idea how many miles are on it after the last owner rebuilt it or what any of the internals are, I hope there pretty strong.
Old Jun 7, 2004 | 07:47 PM
THEGENERAL's Avatar
definatly hope they are...
Old Jun 13, 2004 | 06:15 PM
89_305TransAm's Avatar
Car: '89 Firebird Trans Am WS6
Engine: 305 TBI (L03)
i remember this ladies husband who i work with tried telling me once that if my friend wanted to clean the carbon out of his car a old school trick was to run the engine and dump a cup of water down the intake, i laughed at him and walked away
Old Jun 13, 2004 | 06:42 PM
ljnowell's Avatar
Actually that is kind of an old school trick. The idea is to get the engine running and warm, then give it a little throttle so that it doesnt die when you do it. Then you pour very little amounts of water at a time into the carb. IT will stutter a little bit, but you dont dump enough to kill it. And yes, it does what it is intended to do.
Old Jun 13, 2004 | 06:46 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
had a hydro lock problem on my boat, has a 305, and if any of you know the exhaust manifolds are water cooled. one of the cylinders ahd got a crack in it causing major problems till i put on new heads. def be careful
Old Jun 13, 2004 | 07:16 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
take out the plugs and crank it, if you ever flood it with water again, that will get rid off all the water, we did that to my cuz integra after he ran it in a puddle with a cold air that was scraping the ground go figure...but it works...
Old Jun 25, 2004 | 09:32 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
and man please i warn you just like they did dont wait to get a new air cleaner!!! i had the same one.its in a dump somewere. they dont filter at all(sand in an engine) and they melt as others said. dont wait it could mean your engine too!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
ynk1121
Sep 12, 2015 12:27 AM
Ragtop Man
Sep 12, 2015 12:23 AM
