Fuel Pump to Carb
Old Jul 1, 2004 | 05:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Fuel Pump to Carb
Any after market companies make the sstock fuel pump to carb line?
JamesC
Old Jul 1, 2004 | 05:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I seem to remember Summit or somebody made a steel braided line to go from a mechanical fuel pump to a q-jet, but I can't find it right now.
You could fabricate one yourself. I like this stuff for the raw stock http://store.summitracing.com/partde...N=120%20302419 , bends easily to route it where you want it to go, use your existing nuts and flare the tubing, you've got a new line.
Old Jul 1, 2004 | 10:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Might try Classic Tube too.
Old Jul 2, 2004 | 07:54 AM
JamesC's Avatar
I've searched Fine Lines, Classic Tube, and InLine Tube without success.
JamesC
Old Jul 2, 2004 | 08:02 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Here's the q-jet line from summit:
http://store.summitracing.com/partde...rt=AER-FCP0139
Si.
Old Jul 5, 2004 | 06:43 AM
ji396's Avatar
Car: 86 IROC
Axle/Gears: 10 bolt with 3:23 gears
I ordered one from Inline Tube. I did not see it listed,so I called them (800-385-9452). Tell them what you have and they will take care of you. Fits perfect on my 305 with a Performer manifold and Carter stock replacement fuel pump.
Old Jul 14, 2004 | 05:17 PM
JamesC's Avatar
Ji396,
I finally got around to phoning In Line today. I gave the salesman the appropriate info, but he had no clue. I told him about your situation, and he said if I had your name and/or a part number yada, yada, yada. Part number at hand?
JamesC
Old Jul 24, 2004 | 01:52 PM
JamesC's Avatar
After some difficulties, I did (thanks to ji36) receive the above OEM style fuel line from Inline Tube. The part was described as follows:
86 Camaro, IROC Z, 305 Qjet, Pump to Carb, OEM
At this time, the part number is simply designated as "General." Cost including shipping was $30.31.
At any rate, the part did fit my 85 IROC, and with some gentle massaging fit into place.
Again thanks, Jim.
JamesC
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
