when buying a carb
Old Jul 21, 2004 | 04:47 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
when buying a carb
do you have to get one that has all of the vacuum ports to work on your car, or can you tap into ofther lines in case the carb doresnt have the port? Basically Im asking does it matter what carb you buy or will any do, as long as it fits your manifold?
Old Jul 21, 2004 | 04:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You mean the ports for emissions purposes? Generally anyone putting an aftermarket carb on isn't terribly concerned with preserving the emissions equipment.
Old Jul 21, 2004 | 05:42 PM
2 dope's Avatar
Engine: 305 LG4
unless your province/state rquires them, which mine does. But in Ontario, Canada, we have to have e tests done on cars 20 years or newer, I have an 85, I have to get the e test once and never again, I guess I'll just wait till I get it done then buy a carb, but I want one that at least has a pcv port and egr, or is the egr that important?
Old Jul 21, 2004 | 09:52 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Yes, it is important for both performance and emissions control.
It lowers combustion temperatures in order to reduce emissions from the car, and, as an added benefit allows the timing to advance for better gas milage and performance (or so I've read). Blocking it off or removing it will raise combustion temperatures leading to spark retard which will hurt milage and performance.
Old Jul 22, 2004 | 08:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not going to have spark retard with a non-CC carb.
EGR and additional timing advance are not a chicken-and-egg thing. The latter is there because of the former. If you aren't tuning for emissions, you don't benefit having EGR.
My questions are: 1) What is your intended use for the vehicle? 2) What all have you done to it so far? 3) What carb do you have now?
My gut feeling is after getting answers to those questions the advice will be, "Tune what you have and spend your money where it will make a difference."
Old Jul 22, 2004 | 08:38 AM
five7kid's Avatar
Forget the gut feel.
https://www.thirdgen.org/techbb2/sho...hreadid=250613
Old Jul 22, 2004 | 10:55 AM
2 dope's Avatar
Engine: 305 LG4
I will be using my car on the street for now. I just want it to be more powerful and tricked out so to speak, a sleeper until you look under the hood lol.
I have headers on it, a/c delete, open element air cleaner, a cam from a 350 thats about it for now. Im just putting on the stock intake and carb for now till i get everything sorted out as to what mods i will do later.
Old Jul 22, 2004 | 02:21 PM
Nate86's Avatar
Engine: 4 cylinder
Ah, my mistake.
Sorry for the misinformation.
midge54
Sep 2, 2020 07:13 PM
billybob6110
Sep 23, 2015 01:30 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
theurge
Aug 21, 2015 12:46 PM
