WOOT it runs!!!
Old Aug 30, 2004 | 01:56 PM
Dan86Z28's Avatar
WOOT it runs!!!
Well I just got my 86 runnin and fixed... and DAMN it's fast!! WOOT!!!!
Anyway, I changed the plugs, and they were BLACK.. like fouled black.
Here's a little but of my setup:
350 .030 over
World Products Sportsman II heads 64cc
flat top pistons
Performer RPM intake
Edelbrock 750 carb
5 spd
3.23's (ugh I know.. not for long tho)
My question is, what should I start with to get the plugs to not get black? I assume it's running rich?
The engine is an older build, and this is the 2nd car it's been in. It runs GREAT!! It probably has about 5-6k miles on it. We replaced the Holley 750 carb that was on it with this edelbrock, because I could never get the holley to run right (later found out it was the power valve.. doh)
Anyway, I'm a good mechanic.. The car was origionally a 305TPI/auto, and I swaped the 350/5spd in it when the 305 gave up the ghost (after 175k miles, so I can't complain).
Basically what my rambling is saying is I can fix it, I just don't know a lot about TUNING.. I can wrench with the best of them, but when it comes to the details, I'm kinda lost..
so.. yeah.. help?
Thanks!!
Old Sep 5, 2004 | 06:55 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
If it were a Holley, I'd say, Change the jets. Edelbrock, I don't know, but I bet the manual discusses it.
Old Sep 5, 2004 | 08:25 PM
Dan86Z28's Avatar
changed the 'brock to a 670 stree avenger btw :P
Old Sep 5, 2004 | 11:17 PM
EvilCartman's Avatar
Car: '82 Z28
Put the 750 back on and dump the 670
Old Sep 6, 2004 | 09:37 AM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
Evil is right. My Street avenger is not a good carb for making big HP. It's fine if you want to cruise, but.....................
Old Sep 6, 2004 | 10:33 AM
ljnowell's Avatar
I love my edelbrock carbs, but you would probably benefit from a mechanical secondary with your five speed. However, edels are good carbs, and very easy to tune. Check out this link:
http://www.telusplanet.net/public/gi.../section_2.htm
breaks it down good, and will amaze you with how easy it is.
Old Sep 6, 2004 | 06:09 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
What I'll probably do is replace it with a Holley 650 DP for now, and when I get some heads, I'll go to a 750 Proform main body.
Old Sep 7, 2004 | 10:25 PM
1BADBOO's Avatar
Car: 1979 MALIBU/1986 CHEVY SHORT WIDE
Engine: BRIGGS AND STRATON
Transmission: TH350
Axle/Gears: RONNIE WELLS SHEET METAL REAR END
and did this fix your black fouled plugs
Old Sep 8, 2004 | 11:34 AM
Dan86Z28's Avatar
Yup It's runnin a LOT better now
Old Sep 8, 2004 | 11:09 PM
1BADBOO's Avatar
Transmission: TH350
good i am not a edelbrock carb fan at all as easy as they are to tune they never make as good hp as a holley
greg
Old Sep 11, 2004 | 01:29 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why? The 650 DP would be just right for that engine IMO.
Old Sep 12, 2004 | 09:41 AM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
Because the cam and heads I'm putting in the motor will really need a 750. Heads will be flowing 290-300 CFM, cam 600 lift and 280+ dur.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
