dual carb system
Old Sep 15, 2004 | 07:55 AM
berlinator's Avatar
Car: '84 Berlinetta
Transmission: A4
dual carb system
Im considering going with a dual carb system on my '84 berlinetta. I was woundering if i could find a dual carb intake manifold or if i would have to get one custom built, and if using a dual carb system would even be worth it. The carb i was thinking about putting in was the performer RPM by Eldlebrock
note: I recently purchaced the car and havent put any aftermarket parts on the engine yet, im just gathering info and deciding what parts to buy for when i go to rebuild the engine
Old Sep 15, 2004 | 10:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can buy dual carb manifolds. Why do you want dual carbs, anyway? Is this a show car?
Old Sep 15, 2004 | 11:20 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Waay to hard to tune for the typical car guy. Stick with a single plenum intake and 1 carb. Money better spent for ease and performance. Unless like mentioned it's a show car and needs the cool factor.
Old Sep 15, 2004 | 01:18 PM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Edelbrock has a dual carb manifold. They will even sell you a crate engine with the dual carb setup.
ops32
Old Sep 15, 2004 | 03:59 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, but they have single carb motors as well that make more power and i think cost less....dual carbs, unless your going with some BIG power, are really not worth the money.
Old Sep 15, 2004 | 05:22 PM
ljnowell's Avatar
Unless there is a blower under them, its kinda pointless.
Old Sep 17, 2004 | 07:50 AM
berlinator's Avatar
Car: '84 Berlinetta
Transmission: A4
no its not a show car. i was just unsure if dual carbs would ram more air into the engine and make bigger power or not. aparently its cheaper and makes more sence to just stick with a single carb huh.
i couldnt reply before because for some reason AOL doesnt want to let me post or reply at all. I constantly get this page to come up and say im not logged in or that i dont have access to the page, which makes no sence because i can post on my school computers.
Old Sep 17, 2004 | 11:44 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Dual carbs used to make more power 40 years ago when all that was available was a limited selection of small OEM 4 bbls. Now that you can get pretty much any size carb you want there's not much point.
Old Sep 18, 2004 | 12:51 AM
AnotherfastIROC's Avatar
Car: 06 Envoy, 84 Fiero, 86 Camaro
Engine: 4.2 I6, 2.5 I4, supercharged 355
Transmission: 4L60E, Muncie 4 spd, T-56
Axle/Gears: 3.42's, 4.10's, 3.73's
As Apeiron said the dual carb manifolds are more for the older cars that had a small selection of small carbs. Using the dual carb set up your motor will not produce a strong ewnough vacume signal at either carb to effectivelty atomize the fuel, not to mention the Tuning nightmare you'd have. Once tuned a 72 lotus europa it had 4 1 barrel carbs it was annoying to get them tuned the same and even worse to get the linkage to pull equally on all 4 carbs.
midge54
Dec 27, 2019 04:14 PM
billybob6110
Sep 24, 2016 09:50 AM
Chevy3shitty
Sep 1, 2015 09:22 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
