Holley Fitment problem
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I finally got myself a Holley 700 DP mech secondary, and I am having issues w/fit. It is a 4150 and it has center hum bowls. the stock Dual snorkle air cleaner will not fit onto the carb; the bowl ends (really the float level adjusters) hit the under side of the air cleaner housing before it get's within 1 CM of resitn down on the flange. If I switch to side hung, will that work?
-Tom
-Tom
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
Yeah that will work or you can go open element air cleaner.Another option is a holley 6210 spreadbore carb,that is my solution and it is a DP.You can pick one up on ebay for about 50 bucks if you keep an eye out............
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Go to just about any parts store, and ask for a Mr. Gasket air cleaner spacer. It will look like a 1" tall black plastic ring. It will jack up the air cleaner about 1", so it should fit fine.
I just went with an open element when I got my Holley though, but I really wanna use my dual snorkel again.
Car: 1984 Z28
Engine: L69 305 HO
Depending on the intake manifold and the hood,you might still encounter clearance issues.with a stock hood and any manifold taller than a low rise it would be touch and go with any spacer..............
Engine: LT1, L400
-Tom
Car: 83Z28 HO
Transmission: G Force 5 speed
Car: 1984 Z28
Engine: L69 305 HO
I run a Weiand 8000 and the aforementioned 6210-3 and have 0 clearance even with the hood insulation cut out the diameter of dual snorkel cleaner.I don't know anything at all about edelbrock products but as per holley web site the 8000 is a medium rise intake,that performs greatttttt..........
Car: 1984 Z28
Engine: L69 305 HO
Engine: LT1, L400
Thanks panhead. If bowl replacement is necessary, the 4150 is going back on ebay. The cost of replacing the bowls would put this carb over the amount I was willing to spend on this project. So if the air cleaner spacer idea doesn't work (still haven't had a chance to check it) then the carb will be sold.
-Tom
-Tom
Car: 1984 Z28
Engine: L69 305 HO
I have and am having great performance out of my 6210-3 spread dp.Also I believe RBL83L69 has good luck with these carbs.......Good luck on your quest for the best
Engine: LT1, L400
Yeah, thanks for the tip on the 6210-3. I didn't even know about that carb but it sounds like a viable alternative. I know that no matter what, the Edelbrock has got to go! Even if that means going to a Q-jet!
Transmission: 4L80E/4L80E
The air cleaner that originally came on my 396 ('66 Impala, 325 horse) is a drop base that fits both spreadbore and Holley w/centerhung flow bowls. I converted it to dual snorkel for the '57.
If you can find one of those, you could do the same. I know Impala Bobs (Mesa, AZ) has used parts, they may be able to scare one up. Might be worth giving them a shout (1-800-IMPALAS, or www.impalas.com ).
BlackphantomZ28
Aug 22, 2015 01:00 PM
kah992
Aug 19, 2015 02:55 PM
