will it feed 400 horsepower?
Old Oct 26, 2004 | 11:04 PM
RacerDonnie13's Avatar
Car: 1988 Camaro SC
Engine: 383 Stroker
Transmission: TH-350
Im puttin a carbed 383 stroker in my 88 camaro. My question is will the stock (In-tank) fuel pump supply the needs of a 400 horsepower motor? I will be running the Mallory three port return style pressure regulator. I will be running a Holley 750 double pump carb. THANKS
Old Oct 27, 2004 | 08:25 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
What was your original motor that it fed?
Old Oct 27, 2004 | 11:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
An '88 Sports Coupe would be TBI LO3.
It will probably feed it if it is in good operating condition.
Old Oct 27, 2004 | 04:05 PM
Damon's Avatar
My stock TBI pump is feeding about 320-340HP just fine. Since carbs run at about 1/2 the fuel pressure of a TBI engine it takes a lot of load off the fuel pump and it can move quite a bit more volume than it could in it's original EFI application.
Old Oct 27, 2004 | 05:25 PM
five7kid's Avatar
Unless it was a V6...
Old Oct 28, 2004 | 02:44 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Holleys need to be runa about 7psi constant - if your pump can't keep up, the pressure will drop. You can add an in-line booster pump to help if needed.
Old Oct 28, 2004 | 10:56 PM
Car: 1988 Camaro SC
Engine: 383 Stroker
The car didnt have a motor in it when i bought it but I checked the VIN# and it says that it had a 5.0 305ci motor. So it should work then right???
Old Oct 29, 2004 | 10:19 AM
five7kid's Avatar
No guarantees on the condition of the pump. That's a real crapshoot.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FormulasOnly
Oct 2, 2015 05:52 PM
dusterbd
Sep 29, 2015 08:40 AM
gta892000
Sep 16, 2015 12:37 AM
