Clarification needed...L69 dual snorkel on Trans Am
Old Feb 15, 2005 | 01:53 AM
savagevulcan's Avatar
Car: 82 Trans Am
Engine: Pro Flo Injected 355
Transmission: BW Super T10 4 speed
Axle/Gears: Ford 9"/3.50
I have a 355 but still the stock LG4 intake. I believe this intake is very restrictive so from reading the past threads on the L69 dual snorkel air cleaner, The dual snorkel air cleaner will NOT fit on a firebird because of the different hood angle. Please correct me if i am wrong.
With that out of the picture (i think) what would be the next best intake out there for a carbed bird?
Old Feb 15, 2005 | 10:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have never seen a 'Bird L69 in person, but from what I understand it had a snorkel like the LG4 (perhaps bigger), plus an opening to the top that went to a cowl pick-up. I'll let you do the search for a picture.
You should be able to fabricate a 2nd LG4-type snorkel on the other side. But, you're on your own (at least with regard to help from me) avoiding what may be over there on your vehicle.
Old Feb 15, 2005 | 12:21 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I think it looked like this.
Attached Thumbnails Clarification needed...L69 dual snorkel on Trans Am-c-my-documents-my
Old Feb 15, 2005 | 02:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yes, thats what the L69 Firebirds had.
Old Feb 15, 2005 | 03:45 PM
Car: 82 Trans Am
Do you have a picture of the hood part of the assembly?
So with the dual snorkel out of the picture, what would be the next best air cleaner in terms of air flow, an open element or is it worth it to try and find a functional hood scoop and get that cold air.
Old Feb 18, 2005 | 12:31 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The L69 Camaro dual snorkle air cleaner assembles fit fine on Firebirds. Even the 83-84 Trans Am ram air top fits. My friend put one on his '84 Trans Am. '85-'86 L69 Trans Ams used the same dual snorkle air cleaner as 83-86 Camaros because they lost the turbo ram air bulge on '85-up.
Old Feb 20, 2005 | 04:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
This is what i'm going to do sometime:
http://www.hioutput.com/tech/air2.html
May work a bit better...
Old Feb 27, 2005 | 10:48 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Here we go.....The mid-82 to 84 Trans Ams with LG4 had the single snorkel air cleaner with the air induction hood. The 83-84 L69 cars also had that same air cleaner setup. The 85-86 L69 TA's had the dual snorkel air cleaner with the flat lid and no air induction due to the different hood in 85.
Old Feb 28, 2005 | 05:49 AM
Pheonix542's Avatar
Car: '83 Trans Am
Engine: Carbed 350 290hp 350ft/lbs
Transmission: wore out T-5
i have a friend of mine that has the dual snorkel on his HO from the factory.
I've been looking for one for my bird, but still haven't managed to find yet
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Jlanz55
Aug 17, 2015 07:15 AM
