Way to check if secondaries are opening completely?
Old Feb 16, 2005 | 12:39 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
My secondary shaft seemed a little tight on this new-to-me carb I got and I'm wondering if there's a way I can tell if they go wide open or not.
Old Feb 16, 2005 | 04:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've never tried it, but if I wanted to know, this is what I'd try.
1) Disconnect diaphragm link from throttle shaft.
2) With a piece of paper about an inch or so across, poke the link through the paper and run the paper up to the bottom of the diaphragm housing.
3) Reconnect link.
4) Take it out and drive at WOT. Mark position of paper on the link. If the secondaries will open by hand (you have to open the throttle to allow the secondaries to open) farther than the paper went down the link, they aren't opening up all the way.
Old Mar 3, 2005 | 02:38 PM
five7kid's Avatar
Did you ever try it? Or something else?
Old Mar 3, 2005 | 03:40 PM
Car: '87 Camaro LT
Engine: 355 L98
I haven't had a chance to try it yet since I store the car at my parents' place two hours away. I think it's ok, though, because I got to take it for a spin last time I was home and it pulls really strong. I will still try your suggestion when I get the chance.
Old Mar 7, 2005 | 03:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you don't want to disconnect the link, do the same as Five7 said, but use a paper-clip instead of a peice of paper.
Old Mar 9, 2005 | 01:54 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Yeah the paper clip thing is much easier.
Old Mar 9, 2005 | 04:24 PM
five7kid's Avatar
The issue is insuring your system of monitoring doesn't affect the operation. A paper clip should work, as long as it is stiff enough to stay put, but loose enough to slide on the shaft as the secondaries open.
Shoot, why not rig up a camcorder to watch it?
Old Mar 14, 2005 | 08:34 PM
Car: '87 Camaro LT
Engine: 355 L98
I tried the paperclip method. I made a couple 0" vac runs and the paperclip was pushed down some but when I manually opened the secondaries all the way it pushed the paperclip a lot more, it looked like they only opened about half way. Maybe I'll try it again with paper just to make sure that the paperclip wasn't too tight on there.
Old Mar 15, 2005 | 07:18 PM
Air_Adam's Avatar
Vacuum secondaries will only open up as much as the engine needs them too. It doesn't really sound like a problem.
Old Mar 15, 2005 | 11:18 PM
Car: '87 Camaro LT
Engine: 355 L98
Hmm, ok I guess that makes sense because it pulls pretty strong under WOT and doesn't feel like there's a problem there. It's still doing something weird at cruise in sixth gear, though. Maybe I'll call Holley tomorrow and see what they say.
Old Mar 16, 2005 | 05:11 PM
Air_Adam's Avatar
Whats it doing in 6th?
Old Mar 16, 2005 | 11:30 PM
Car: '87 Camaro LT
Engine: 355 L98
https://www.thirdgen.org/techbb2/sho...hreadid=283510
Terrell351
Jun 13, 2021 01:13 PM
Infested
May 22, 2018 11:56 PM
Casey Meyers
Mar 2, 2016 10:46 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
KO1
Aug 31, 2015 06:31 PM
