q-jet, what does this do? (choke pulloff screw?)
Old Apr 3, 2005 | 01:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I was hoping someone could tell me what turning this screw does. It's probably the one thing on my carb that I'm not quite sure about. This pic of a cc-qjet, (thanks to whoever I stole this from!), but mine is non-cc, but same part...
I know it has to do with the choke pulloff, i'm just not sure what'll happen when I turn the screw either direction... something with the fast idle?
Thanks -J
Attached Thumbnails q-jet, what does this do? (choke pulloff screw?)-c-documents-settings-jay
Old Apr 3, 2005 | 02:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It adjusts how far that vacuum daiphragm cracks the choke blade open after the car starts up cold.
Old Apr 3, 2005 | 02:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
aha! that's kinda what I thought... So if I tighten it, that'll keep the choke blade closed more when first cold starting, and give me a richer mixture at start up?
I keep having the car stall when cold starting, it'll rev up to 1500 then start to stall, I have to keep tapping the gas to keep it running.
Old Apr 3, 2005 | 04:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You might want a leaner choke setting if that's what's happening.
Old Apr 3, 2005 | 04:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea, that sounds right, i'm probably flooding it eh?
turning it outward will lean it up then? I'll give that a shot here...
Old Apr 3, 2005 | 06:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, don't touch that screw. Adjust the tension on the choke coil so it comes off sooner.
Old Apr 3, 2005 | 06:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
hmm, well too late... Well it all seemed to be ok, it'd have a nice cold idle, then go down to low idle... but when I rev it, it'll stay up at 2k rpm, as if high idle, and i'd have to kick it down again... however the choke blades were wide open the arm was down...? so anyway, I tore it apart in record time, and then.....
Well i'm going to start a new thread in the engine forum, stay tuned....
Old Apr 6, 2005 | 01:03 AM
DeLorean247's Avatar
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
HEY! you took my pic!
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
