holley SA w/hei vacc advance carb
Old Apr 8, 2005 | 09:44 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
I'm currently swapping out the stock intake/ carb for a edelbrock rpm air gap, and a holley street avenger carb, i have a hei vacuum adavnce distrib for it, and am not quite sure how to hook it up, am i able to use the distrib cap from my old distrib for the hei ? and where do i hook up the vacuum line from the distrib ?
Old Apr 9, 2005 | 08:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
All of your information says "TPI". What "stock carb" are you changing out?
Large cap (i.e., coil in cap) HEI distributors all use the same type cap.
Connect the vacuum advance to the port on the passenger side of the carb, at least as a starting point.
Old Apr 10, 2005 | 08:07 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
the info on my sig is "my car" which is a tpi, i also have a carbd 86 trans am, which is going to my gf. sorry for the confusion, thank you for the help
Old Apr 13, 2005 | 04:31 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I see your in oxnard i go to itt tech there i live in moorpark.
The vac line will go to the manafold vacuum on the carb not ported.
Old Apr 13, 2005 | 05:48 PM
five7kid's Avatar
Why do you say that?
Old Apr 13, 2005 | 05:50 PM
FAST RS's Avatar
Remeber the thread about vacc advance and what port to use it seemd like it was better to use manafold vacuum insted of ported. Unless i missed somethin?
Old Apr 13, 2005 | 06:31 PM
five7kid's Avatar
Most HEI vacuum advance units are intended for ported vacuum. If you get one that's adjustable, go ahead and play around with manifold vacuum.
But, as that other thread did imply, use what's best for your combination. Notice I did say above "...at least as a starting point". And, in the noted thread, that manifold works very well on my 396.
Old Apr 13, 2005 | 06:33 PM
FAST RS's Avatar
I totaly missed that part.
Old Apr 13, 2005 | 07:03 PM
five7kid's Avatar
All is forgiven, then...
Old Apr 16, 2005 | 04:00 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
no kidding ? i havnt seen anyone in this area should meet up sometime
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
