1406 setup
Old May 16, 2005 | 02:40 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
1406 setup
I'm trying to get my carb all setup and ready to go, but have some questions. The port for the PCV, do i just leave this open if i dont have a PCV? This is a v6->v8 swap and it's all non-emmissions.
Also, how should i wire the electric choke? Does this just receive +12 from the bat or alt or should it be on a switch?
I dont have ANY of the original wiring, everything is getting custom wired.
Old May 16, 2005 | 04:10 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
i am actually in the process of the same swap. I would make sure to get your PCV valve because i think it will make it have trouble idleing wrong, someone please correct me if im wrong. I am having a hard time finding out whether or not i need to do any modifications to the throttle linkage, and what i need to do. Let me know if you figure this part out.
Old May 16, 2005 | 04:35 PM
Car: 88 Camaro
Engine: 310 LG4
well, if u have a 700r4, you should get a tv made ez kit from bowtie overdrive to make sure your tranny works as it should, they have brackets for your throttle cable as well. Do not get a lokar setup, they are junk and they bend.
Old May 17, 2005 | 05:35 PM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
You definetly need to hook up a PCV to the 1406. If your valve covers do not have breather holes for this, I suggest getting some that do. The way it connects is the vacuum line in the front of the carb hooks to the drivers side valve cover and the passengers side cover either has a breather cap with filter or a hose running to your air cleaner assembly grabbing air after the filter. if you don't hook this up, the car will idle really high (about 2000 rpm for a normal setting) If you lower the setting down to the recommended 750 rpm idle, it will idle so rough, you'd swear you're going to break a motor mount (at least my 1406 did without the valve hooked up) The electric choke needs to be wired to a source that is only on when the car is running. I wired mine to the turn on wire for my stereo since it was easily accesible to me, but any switched source will do, even a homemade one (just dont forget to turn it off after you shut off the car)
Old May 17, 2005 | 06:09 PM
Car: 88 Camaro
Engine: 310 LG4
can i cap off the pcv port, or leave it open to achive the results i need? I'm limited on $ and i already have the valve covers and breathers. is there any other way that doesnt require that i ditch what i've already bought and isntalled?
Old May 17, 2005 | 06:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Cap the port if you want, but you'll be increasing your oil contamination just to save the cost of a $5 PCV valve and a foto long piece of 3/8 hose.
Old May 23, 2005 | 11:36 AM
Car: 88 Camaro
Engine: 310 LG4
it's not that i dont want to buy a pcv, it's that i already spent $ on the damn breathers. So what are the breathers for then? Shouldnt that the the same thing? I thought PCV was to take the fumes from the crank case and put the back through the carb for emissions? Wont the breathers do the same thing, except just release the fumes into the engine bay?
Old May 23, 2005 | 12:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which isn't a good thing. And not all that effective, since there's no delta pressure between the breathers.
Breather on one valve cover, PCV valve on the other. That's the way to go.
Old May 23, 2005 | 12:41 PM
Car: 88 Camaro
Engine: 310 LG4
ok, so i should run a breather on the pass side, and pcv on driver side eh? I guess i will do that then. Thanks.
Old May 26, 2005 | 04:10 PM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Yeah, the reason for the valve and hose is to use vacuum to pull the vapors out of the engine rather than let them float out. If theres no pressure negative (sucking) or positive (blowing) then the vapor wont really move at all and stay stagnant.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
