anyone ever ran this setup before???
Old Aug 7, 2005 | 09:19 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
I am droppping my 406 in this week sometime and wanted to know if anyone has ran this setup before and if they had any problems or recommendations. car was originally an lg4 so it already had the mech pump on block with return line and the electric in tank booster. 650 holley dbl pumper for carb. I got a carter with return line and NO regulator is this OK???
Old Aug 7, 2005 | 11:49 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
what is the summit part # for the carter pump?
Old Aug 7, 2005 | 11:50 PM
jstoltz's Avatar
don't have it here off hand it was one that five7kid mentioned I beleive it is 4-6 psi. not positive though
Old Aug 7, 2005 | 11:53 PM
BT283's Avatar
if it is just a 4-6 psi and its not like a 3-15 it will probably be fine as long as it is enough pressure, i usually run my holley on about 8 psi
Old Aug 7, 2005 | 11:55 PM
jstoltz's Avatar
that what I kinda thought too but just checking. I got a brand new carter strip pump I was going to use but if I did I was going to weld in sump on the bottom of the tank and run new lines then I would need a regulator also. figured this way is alot easier. Thanks
Old Aug 8, 2005 | 10:24 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Carter p/n with return is M6626. I haven't heard of anyone using it with a pusher electric without a reg, however. I don't know any reason it wouldn't work.
Old Aug 8, 2005 | 10:48 AM
jstoltz's Avatar
what is the psi on the m6626? I kinda figured this 406 would need all it can get.
Old Aug 8, 2005 | 11:46 AM
five7kid's Avatar
6.
6 is enough to run a 406. Volume is the issue with a bigger engine, not pressure.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
earlpote
Sep 12, 2015 11:55 AM
