demon and throttle bracket
Old Aug 17, 2005 | 11:43 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
anyone know what kind of throttle bracket i can use on a demon carb. it's a zz4 350. im seing the crapy spectra one now but haveing some issus with it turning on me.
thanks
Old Aug 17, 2005 | 01:29 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Contact Jimmy @
http://www.jimmy-jams.com/
He makes a Demon throttle bracket that works very well and is cheap.
Old Aug 17, 2005 | 01:33 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Thanks i should have mentioned has to be the throttle and tv cable in the pic does'nt look like it has the tv bracket.
i ordered from them before good stuff
Old Aug 18, 2005 | 12:47 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I use CSR Billet Adjustable Throttle and TV cable bracket part number 621 it's about $60 through Jeg’s. It has fully adjustable TV cable and throttle cable, also a place for your throttle return spring. It also come in like 5 different colors if that matters.
Old Aug 20, 2005 | 01:25 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I use a generic ol' Holley bracket with the little "tab" bent up
Old Aug 23, 2005 | 01:56 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Absolutly does not fit! i just got the bracket in today csr-621 and the bolt holes dont line up and the pump arm hits the bracket also there is no place for the throttle return spring.
Old Aug 23, 2005 | 02:16 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Really fits my car fine. What kind of demon do you have i have a speed demon. I will go out take a picture right now for ya if you want. Also the notch in the back of the bracket is for the spring I do not use this notch cause I don’t have a proper length spring.
Old Aug 23, 2005 | 02:26 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Pictures
Sorry pictures are so blurry its ranning outside.
so yours is hitting here?
my wholes line up fine.
Old Aug 23, 2005 | 02:29 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
mine dont look like that but it is the csr 621.
i'll take a pic
Old Aug 23, 2005 | 02:37 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
maybe it is the wrong part cause it says csr 621 and it says for 4500 carbs but that was the only thing there.
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
I have to get going to work. give CSR a call the toll free number on there website http://www.csr-performance.com/ make sure you have the same one as me.
Later
Old Aug 23, 2005 | 02:39 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Old Aug 23, 2005 | 02:41 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Old Aug 23, 2005 | 03:11 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Wrong part...that is for a 4500 series carb..ie Dominator,King Demon.
You need the part number for a 4150 series carb!Send it back!
You need one of the 170-631 series brackets in whatever color you want.
Old Aug 23, 2005 | 11:34 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
i looked on csr's website and it's showing the part number for what they sent me as a 631 and the blue one as znuclearz has as 621
i believe csr packaged it wrong so i ordered another one
well see what happens.
Old Aug 24, 2005 | 01:43 AM
meeklay812's Avatar
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
I have a friend who used to have a demon and he used that bracket. It looked nice in the engine bay and seemed to have a nice tight fit with the cables. I used one of the cheap adjustable ones from spectre and will never use one again. Began to bend pretty easily.
Old Aug 24, 2005 | 09:50 AM
Bobbyz's Avatar
Engine: 350 "ZZ4"
yeah i have the spectre one on there now and it sucks.
it was a temporary fix until i found somthing better.
Old Aug 25, 2005 | 01:31 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
hey znuclearz did you get the part number from the csr website? because you have the 631 bracket not the 621.
i called csr and told them and they noticed the pictures were in the wrong spot. the 621 was in the 631 spot and vice versa.
Old Aug 25, 2005 | 01:54 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Yes I got the part number from CSR's website. Sorry I wasn’t paying more attention to the actual part instead of the picture . I don’t have my actually packing anymore so I can’t tell you for sure witch one I ordered. I got mine from CSR about a year ago, I actually just called and told them what carb I had and witch type of TV cable and throttle cable wither factory gm cables or Moroso cables. Sorry I got the part number wrong.
Old Aug 25, 2005 | 02:22 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
not a problem i was just banging my head for a while there ordering the wrong part twice lol. but now i think i got it right.
Old Aug 28, 2005 | 10:57 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
summitracing.com part# EDL-8031
Thats what i got on my demon, and it works great.
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
Randomtask2
Sep 7, 2015 05:06 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
