Question on carb tuning...Demon 650
Old Sep 1, 2005 | 01:58 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm still on my non-stop quest to tune this carb correctly. Been a year and a half now, and still not quite right. lol
Here's how I kinda have it adjusted now:
I set my timing until I got the highest vacuum reading with the throttle blades closed and adjusted to Demon specs at .020 transfer slot clearance. I end up with 21 degrees BTDC. The engine also seems to rev quicker at this setting and run smoother.
Then I adjust each A/F mixture screw in until I get the highest vacuum reading from each one. I end up with a max manifold vacuum of around 14". It runs smoothly, but the idle is way too high. Around 1100 RPM's.
I have the "Idle Ease" feature on the carb, so I try to adjust that in order to decrease the RPM's down to where I'd like to see it idle (around 850), but I can't seem to get the RPM's down enough using idle ease alone. But I don't like idling at 1100 rpm's - even if it is smoother.
So what should I do next?
- Decrease initial timing (back it off) until I acheive 850 at idle?
- Close down on my throttle blades? Keep in mind I'll lose the supposedly required .020 transfer slot clearance...
The Demon manual says you want to end up with, and I quote:
"The goal for best quality idle and throttle response is to have the engine idle with the butterflies closed, at the correct RPM, with the highest manifold vacuum, and the mixture screws adjusted between 1 and 2 1/2 full turns out from fully closed."
Then it adds a disqualifier that says "your particular combination may function correctly ouside this range."
So I ask you, the carb gurus here - and I know you're here....what am I doing wrong??
Old Sep 1, 2005 | 02:29 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
What is your total timing at?
Old Sep 1, 2005 | 02:48 PM
Confuzed1's Avatar
Car: 83Z28 HO
Straight Mechanical HEI. Total advance is in at around 2500 RPM's and I end up at 40-41 degrees.
Old Sep 1, 2005 | 03:03 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Why so high?
Even when you set the trasition slot...I would still turn them down after the mixture screws are set to get the rpms down.Just make sure to go equal amounts.I have found no other way to get my Demon to idle down.
I used to run straight mechanical.Cured a ton of tuning issues/problems on my Demon 750dp by going back to vacuum advance as well.
Old Sep 1, 2005 | 03:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would have to agree. 40 degrees total advance is too much. The best way to get the total advance you should have along with the idle advance the engine/carb seems to want is to use manifold vacuum advance.
Old Sep 1, 2005 | 03:47 PM
Confuzed1's Avatar
Car: 83Z28 HO
Why so high?
I know optimal, or so I've heard is 36-38 degrees total. And it is high. But it's just where it ends up after adjusting for best vacuum at somewhat of an idle.
I suppose there's some way to limit the total advance in the distributer- maybe an adjustment or a bump stop or something, but I have'nt fooled with that.
OK, but after I do that, should I readjust all the A/F screws again for best vacuum or not?
I guess that's two votes to get a vacuum advance distributer...but how will it help me? I guess what I'm asking is - how will that allow it to idle better, etc??
Old Sep 1, 2005 | 03:58 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
A.No..I don't and my mixture is fine and the car runs great.
B.I asked this same question when I ran mechanical.40-41 is too high.34-38 is optimal depending on the combo.Right now you are over that just to get the idle and part throttle timing you need to make the car run well down low.With manifold vaccum you can run an easy 14 initial and an additional 9-10 vacuum to make up 23-24 degrees at idle.Great for throttle response and part throttle.But when your on it at the top end..the vacuum goes away leaving you with the optimal 34-38 degrees.All depends on where you set your initial and the curve in the distributor.Vacuum advance has no ill effects on performance..but is an excellent aid in ANY street car.I used to disagree till I learned how to set it up and tune it right.Now I won't live without it..lol.Get yourself a vacuum advance distributor before anything else.You will understand why once it's tuned.
Old Sep 1, 2005 | 08:19 PM
Confuzed1's Avatar
Car: 83Z28 HO
Thanks again onebad82z -
OK, I guess I'm gonna try a vacuum advance distibutor then. I've stubbornly held onto hopes this would work out with the straight mechanical advance, but I give up!
That brings just a couple more questions if ya don't mind...
1. Would I port it to full manifold vacuum or above the plates?
2. So if I get a vacuum advance, should I adjust the timing where it runs and idles best at now, leaving the vacuum hose hooked up, or adjust it to give me 34-36 degrees at around 2500 rpm's?
- How will I end up with 21 degrees at idle (where it does best)??
- Any recommendations on a decent vac advance distibutor? Will a stock one do?
OK - that was 3......
Old Sep 1, 2005 | 09:05 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
1a.I run ported.Seems to work best for me.Try both and see what works better..every car is different.Although I venture to say it will like ported better.
2a.I adjust for total timing (say 36 degrees) and then swap bushings in my MSD to get the initial (and vacuum timing) that works.You may have to get the distributor recurved if you can't get a curve to work in a stock HEI.I went with the MSD #8361 as it is tuneable with bushings to give varied amounts of mechanical advance.I only add about 9 degrees with the Crane adjustable advance.You can make a simple plate that can limit vacuum advance as well on a stock can and distributor.I will link a few posts that have some great info on this.
3.Any recommendations on a decent vac advance distibutor? Will a stock one do?
3a.I recommend the MSD #8361 as I have it and it works great.I can also say just about any HEI vacuum distributor will work with tuning.An indespensible tuning aid is the Crane series adjustable vacuum cans.The #8361 requires a can for a points style GM dist.
Not a problem!
Old Sep 1, 2005 | 09:14 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Read these:
My original problem when I didn't beleive in vacuum advance:
https://www.thirdgen.org/techbb2/sho...vacuum+advance
Assorted vacuum can specs:
And this article is what finally made me realize why I needed to go back to vacuum advance:
https://www.thirdgen.org/techbb2/sho...ghlight=ported
And this is a great tech article on how to modify a stock vacuum HEI to wrk great on a modified car:
https://www.thirdgen.org/newdesign/tech/hei.shtml
Old Sep 1, 2005 | 10:28 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Yes, even the original HEI GM distributors are really good. Pick up the proper Crane vacuum can kit to go with it and set it according to instructions, usually something like 9 or 10 turns counterclockwise with the included allen wrench. Then setup the springs to work. I find that the stock weights and one light and one medium spring give the best advance curve for me. Your's may differ.
Get a good cap, coil and module, too. Proform stuff is good and not expensive. Good luck!
Even a junkyard HEI unit is good to start with. Only thing that goes wrong is usually the bearings.
PS Crane has a new distributor setup out that does everything with a computer chip; the "vacuum" advance and then the curve. Has a number of different settings built in for both ends so you can experiment. It looks really slick. Saw it on Horsepower TV this last weekend.
Old Sep 2, 2005 | 08:26 AM
Confuzed1's Avatar
Car: 83Z28 HO
WOW!!!
THANKS ALOT! I can see that you really have "been there done that" onebad82z! It looks like a lot of good reading I need to do.
By just glancing over it all so far, I'm seeing some of the same issues I've been having since day 1 with my setup. Don't get me wrong though...except for being able to get enough advance at idle in order for it to run right, it's got gobs of power at WOT.
But - I can tell you it sucks down gas like no tomorrow on the street, and the engine is hard to turn over and start with my timing set at 21 BTDC at idle where the engine likes it. It's like the compression is working against the starter. I'm on my 2nd hi torque starter already.
But like i said, my total advance ends up at 41-42 degrees which I know isn't right.
I've even tried backing the timing down from 21 to 16 degrees initial BTDC at idle, which actually gives me 38 degrees total, and I adjusted the carb so itl would still idle OK(although rough), But it wants to run hot when I do that. Even with a Griffin aluminum radiator and 180 degree T-stat.
Again, I thank all you guys that responded, and I garauntee I'll have a few more Q's after I read through all this great info - I'm a little slow... - if you guys don't mind a painfully long post... lol
Old Sep 2, 2005 | 08:41 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
"But - I can tell you it sucks down gas like no tomorrow on the street, and the engine is hard to turn over and start with my timing set at 21 BTDC at idle where the engine likes it. It's like the compression is working against the starter. I'm on my 2nd hi torque starter already."
With the vacuum advance the initial will be able to be set at a much lower 14 or so degress let's say (again your combo will vary)..a ton easier on starters.I had the same problem with only mechanical.I can't count how many times I stopped to get gas..kid pumping gas at station is drooling on the car..then it doesn't start..doh!As soon as the car fires up the vacuum adds another 9 or so degrees giving you the 23 degrees at idle that makes the car run so well down low.Remember the vacuum only adds timing when the car is running..lol.And you will notice the car using less fuel down low..I know I did.
"I've even tried backing the timing down from 21 to 16 degrees initial BTDC at idle, which actually gives me 38 degrees total, and I adjusted the carb so itl would still idle OK(although rough), But it wants to run hot when I do that. Even with a Griffin aluminum radiator and 180 degree T-stat."
It will run hot with the timing retarded like that.Beleive it or not vacuum advance will help it run cooler at idle and low rpm cruising from the additional timing...much like when you ran the 21 degrees.But it allows you to keep total timing at the more ideal 36-38 since it is non existant at WOT.
"Don't get me wrong though...except for being able to get enough advance at idle in order for it to run right, it's got gobs of power at WOT"
It should have enough power..it's a healthy 400.Starting to build mine as we speak
Old Sep 7, 2005 | 01:45 PM
Confuzed1's Avatar
Car: 83Z28 HO
OK - I've read all the posts you kindly referred me to onebad82z, and it's alot of good reading!!
But the part that confuzes me (pun intended) lol, is you mention briefly above about running a ported vacuum to the canister, and it may work best for me.. Now, I think ported vacuum comes from above the throttle plates, so there would be no additional "advance" after the engine starts, correct?
So-
I should be able to run manifold vacuum to the canister (below the throttle plates), and I would then have additional advance after startup - right?
So -
If setup with full manifold vacuum, at idle my canister will be advancing the distibutor plate as far as it can correct? Then if I give it part throttle (like going up a slight hill) the canister would slightly retard the timing correct? And if I gave it WOT all at once, the canister will go to full retard until RPM's increased and I start regaining vacuum, at which point it would start advancing the timing again.
So-
If I set the timing up right, I could get away with say 14-15 degrees BTDC static (hose disconnected), and then set the canister to provide my additional 6-7 degrees of advance at idle (to make 21 BTDC), then i can limit my mechanical advance to 32-38 degrees at around 3200 RPM's - correct?
Just wanted to get your take on this, and to make sure I have the whole vacuum advance concept right in my head..
BTW..I think I need to get the MSD 8365 instead of the 8361, since I have an HEI distributor. Besides, I like the idea of the built-in rev limiter.
Old Sep 7, 2005 | 02:05 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
First off please let me correct some wrong info I stated here..
I run MANIFOLD.Anywhere is says ported replace it with MANIFOLD.Very sorry for that misight.Duh!
1.Yes you are correct.It is from above the throttle plates.There should be no vacuum at idle if the transition slot is correctly set..you are correct.But as soon as the throttle plates are moved it will pull vacuum on the can.
So-
1.Yup.Vacuum advance will be there at a still idle.No throttle movement.
So -
1.Yes.Well as far as it can depending on the vacuum your motor pulls at idle.Some cans need 10 degrees to fully advance...some need 15.Again refer to
to see what can requires what timing at idle to advance the timing.
1.It won't retard it...you'll just lose the additional from the vacuum can.You are right in thinking though.
1.More than likely anytime at WOT there should be no vacuum (unless your carb is too small) so it will only be initial plus mechanical.No vacuum aided additional at WOT.
So-
1.Yup
1.I am no expert...but with what I know about it..you seem to understand it better now.
That would work just as well.The mechanical advance can be limited by bushings like the 8361?I chose to go with the 8361 as I was running the 6AL with an external coil anyway so why run the large cap when it was empty.
Old Sep 14, 2005 | 10:37 AM
Confuzed1's Avatar
Car: 83Z28 HO
Yes, it has bushings just like the others to set mechanical advance according to thier website. I ordered it yesterday (the 8365), so I should get it in a couple of days.
Thanks for all the assist/advice onebad82z - and others!! I'll most likely post back on this thread when I go to tune the advance curve. Never done that before, but with the info you gave me, it SHOULDN'T be too big of a deal...I hope!
Old Sep 14, 2005 | 12:27 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Not a problem!
Let us know when ya get it in and start tuning.
Old Sep 21, 2005 | 12:16 PM
Confuzed1's Avatar
Car: 83Z28 HO
Allright - It's in. Nice looking distributor!
Too bad the one I'm taking out is also a nice looking Proform billet mechanical.
I set it up with the black bushing to limit mechanical to 18 degrees according to the instructions. I went with the two (light) blue springs (slightly aggressive) for the weights. The distributor cap is a pain though. I have to remove my wires to get the cap on/off.
I set the rev limit to 5800 for now. I started it up, and with the vacuum hose disconnected from the advance, I set max timing to 36 degrees. That left me with about 18-19 degrees at idle while disconnected. And I pull about 13 -14 inches of manifold vacuum at 750 rpm's. Idles smoothly but seems to surge just slightly.
Now get this:
When I plug in the vacuum advance, It's suddenly 32-34 degrees advanced, and idle jumps to 900-1000!!
So I slow the idle down to 800 rpm's, and I'm still at 32-34 degrees while idling. Does that seem excessive??
I may end up stepping down to one light blue spring and one heavy silver spring to lengthen the curve a little. I get 38 degrees at around 3000 Rpm's. But it starts up fine.
If I tried advancing my straight mechanical distibutor that much, it wouldn't even crank over.
Am I going in the right direction here so far as tuning?? I'm open to "constructive" critisizm.....
PS: I gotta feeling that what's happenin is the inital is 19, and the vacuum advance supposed to add up to 10 degrees advance at 15" vacuum. Since I have 13" at idle, I think the vacuum advance is adding about 8 degrees, but I'm just guessing.
Old Sep 21, 2005 | 12:26 PM
five7kid's Avatar
Sounds right to me.
If you are getting some starter kick-back, then put more mechanical advance in and retard the intial advance so that you maintain the 36 total w/o vacuum.
Old Sep 21, 2005 | 01:49 PM
Confuzed1's Avatar
Car: 83Z28 HO
Originally posted by five7kid
Sounds right to me.
Nope, no starter kickback.
I just drove it around the block, and it definatley didn't lose any power. Seems to run strong still, but I have idle issues...every once in awhile it dropped below setpoint and stalled when rolling up to a light. I may have to open up the transition slot a little on the primaries and get idle up to 800-850. It's around 750 now.
I don't hear any pinging, or I'm deaf. I almost expected it with the curve I have in now. But I do think I hear a lifter ticking. I gotta adjust them again I guess.
I do have a question though...when it was dynoed, the torque was at it's highest by 3400 rpm's, with 38 degrees total. Should I change springs around to try and get all the mechanical advance in by 3400?
Old Sep 21, 2005 | 01:57 PM
five7kid's Avatar
Where's it coming in now?
Unless you have sky-high CR, earlier is typically better, as long as it isn't advancing at idle. Mine is all in by 3000.
Old Sep 21, 2005 | 07:53 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
1.Swap the black bushing out for the blue one giving you 21 degrees additional mechanical advance.Then set initial at 15 degrees to start.I run one light bue spring and one heavy silver...brings in my total to right around 3200rpm's.You will make up the missing initial with the vacuum.
Now get this:
1.The timing (and the idle speed) jumped as the vacuum can was adding additional advance due to the manifold vacuum present.Normal.
1.Not necessarily,but you may need to limit it.I usually set my initial at the lowest rpm I can get the car to hold an idle (with no vacuum can).Once set I plug the can back in which raises the idle...I then set it to my desired value.I limited my vacuum advance on the Crane can with a limiter to only add 9 degrees at idle.My initial with vacuum is 21 degrees.Small blocks can take alot of timing at idle...with my can adding full advance (32-34 idle) my car would idle fine but detonate at light cruise.Limited the vacuum can and it fixed it.
1.I have always had best luck getting it all in by 3200-3400.Try it (one light blue spring and one heavy silver spring to lengthen the curve a little)and see what the car likes.
1.Sounds about right.
1.Had the same problem...was a mixture of transition slot coverage and ide mixture screw settings.
1.I can't hear my car detonate or ping.I feel it.Don't know if it has to do with the forged bottom end (can't see it)..but it does not ping.It breaks up when it detonates.Pay attention to the car real close...may have the same situation.Just a thought!
1.Dyno numbers are great.But...did you have all the accesories on the motor when dynoed?Same exhaust as on it now?In car conditions change the power curves around forcing you to tune accordingly.Best way to really tune timing with the motor installed IN THE CAR is at the track.
Old Sep 21, 2005 | 09:37 PM
Confuzed1's Avatar
Car: 83Z28 HO
Thanks for the assistance!
About 2800. I have 9.5:1 compression.
Now I'm confuzed...since my car seems to want to idle best at 21-22 degrees initial even with the straight mechanical dist. installed, if I used the blue bushing I'd end up with 45 degrees total if I didn't limit it right?
That's why I chose the black bushing which limits the mechanical to 18 degrees - and I want total advance at 36-38 degrees max correct? -or am I missing something? I can't even keep it running with only 15 degrees initial.
My vacuum advance isn't adjustable. I'd have to get the Crane unit for that. But it's something I may need to look into.
Yeah, I think I'll try that next, but the bushing thing still baffles me.
Yeah, makes sense. They get dynoed with open headers etc. -Just asking.
- But I'm getting closer to getting this right....I can feel it!!
Old Sep 22, 2005 | 08:09 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
1.The blue would give you additional mechanical advance of 21...then set the initial to 15 or so.You now have 36 total.Add in another 8 or so vacuum can degrees at idle..you have 21 degrees at idle.
1.With each bushing you have to add different degrees of initial to get your desired total.Vacuum advance will help add in the missing initial..but wont over advance at WOT.
1.I had no choice but to get a Crane can...stock can (even the MSD one) added way too much.
The black bushing add 18 mechanical..to get 36 total you would need 18 initial.
The blue bushing add 21 mechanical..to get 36 total you would need 15 initial
I don't even remember the other bushing...but you get the point right?lol
Old Sep 22, 2005 | 10:42 AM
Confuzed1's Avatar
Car: 83Z28 HO
OK - I do understand what the bushings are doing then. I guess the only problem is that it won't idle at 15 degrees initial - or doesn't that matter since I'm hooking up the vacuum advance anyway??
Old Sep 22, 2005 | 10:54 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Vacuum advance will add the necessary additional timing needed to allow the car to idle.
Old Sep 22, 2005 | 12:25 PM
Confuzed1's Avatar
Car: 83Z28 HO
Ok, That's basically the way I started out - I adjusted timing to 21 advanced with vacuum hooked up and adjusted idle.
But this time This time I revved to wherever the mechanical advance stopped and set it at 36 degrees. Then I let my initial fall where it may, which happened to be 18 before. Plugged in the vacuum advance and ended up idling at 30 plus degrees.
I can try the blue bushing and see what happens, but since I set timing at 21 initial advanced + 21 (blue bushing limit) - won't I end up with 42 degrees total advance? I thought I actually need a thicker bushing than the black one that could limit mechanical to 15 degrees, and that would make 21 initial + 15 mechanical= 36 right? Or am I missing something?
I'll try the light blue and heavy silver springs together too and see if it's better.
Old Sep 22, 2005 | 01:12 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
1.Yes..but..Set the initial timing without vacuum can to 15 degrees.That plus the additional 21 added with the blue bushing will give you 36 total.Then hook up vacuum and see what you have.
1.Swap the numbers and you are correct..
Blue bushing limits mechanical to 21 degrees, so then that would make 15 initial + 21 mechanical= 36 total
Old Sep 22, 2005 | 01:22 PM
five7kid's Avatar
I think you need to get over the hurdle of the differences between timing adjustment and timing in operation.
You set/adjust the timing without the vacuum attached. You set/adjust the idle with the vacuum advance operating.
The initial timing and the timing needed to get a good idle and proper idle speed having nothing to do with each other. You may need to screw the idle speed up during the timing adjustment operation, and there's nothing wrong with that.
If using the 21 degree bushing gives you 42 degrees full mechanical advance, set the initial advance back 6 degrees so it's back to 36 degrees. There really isn't any reason to have 21 degrees initial advance (no mechanical coming in, no vacuum attached). 15 initial and 21 degrees mechanical makes a lot more sense to achieve 36 total mechanical than the other way around. If the engine wants more initial advance than that to idle properly, give it manifold vacuum for the vacuum advance after you've set the initial advance, and adjust the idle mixture and speed after that.
Old Sep 22, 2005 | 02:14 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I could not have explained it any better than five7.That should clear it up a lil more for ya..lol.
I think I may have been confusing you as well.Not the best with words.
Old Sep 22, 2005 | 07:17 PM
Confuzed1's Avatar
Car: 83Z28 HO
Thanks for the explanation 5-7!...it's a bit clearer now.
I didn't pick this screen name for nothin...
There are reasons I'm asking though. If you go by MSD's instructions for the distributor, it tells you to hook up vaccum advance to the ported (above throttle plates).
But I realize that won't work. Then it tells me the mechanical advance should not start to come in until after idle. Then this also kinda "confuzed me:
With a 21 degree bushing, that would have to be 15 degrees right? Well, I can't get the car to hold an idle there.
So - anyways, I guess I need to listen a little more and quit tryin to nuke this. I'm overthinking this it seems.
Anyways, I re-installed the blue bushing, and changed springs to 1 heavy silver and 1 light blue.
Gettin too late to run it today, but tomorrow, I'll try setting it up as you both have suggested and see what happens!
Old Sep 22, 2005 | 08:39 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
1.Yeah I read that to..but I had better results with my MSD hooked to manifold.The car should not idle with mechanical advance trying to come in.If it is the springs are to light and will give you an idle that constantly hunts/revs up and down and the total will be in to quickly leading to detonation at cruise.
1.Set the idle as low as it will alow.Set timing to 15 degrees.You may need to increase idle speed once the initial is set at 15 degrees.Once set ..hook up vacuum advance to manifold...then turn the idle down to the desired speed.
Old Sep 26, 2005 | 04:42 PM
Confuzed1's Avatar
Car: 83Z28 HO
OK - did that, and seems to run great with the bushings/springs you guys recommended. I still have an issue with it stumbling below idle ocassionally and dying. I think I'll need to tweak the transfer slot adjustment a little and I might be OK.
Idling at 850 with my vacuum line hooked up, I still run 31 degrees advanced, but it seems happy there, and during the test run it didn't seem to ping under light load, and has tons of kahunas!
I'm gonna go ahead and put my new spark plugs in and check them after awhile. I'll be happy with any color other than black! lol
Thanks for the help!!
Old Sep 27, 2005 | 08:02 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
1.Sounds like either the transfer slots need to be reset,Idle mixture is still a tad lean,or a vacuum leak somewhere.
Otherwise
Old Sep 27, 2005 | 04:34 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Hey i was wondering i also have a demon 650 with 4 corner air/fuel screws.
is there a certain sequence for adjusting the air fuel like fronts first or rear ones first or it does not matter
Old Sep 27, 2005 | 06:40 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Set all four screws at 1.5 tuns out (CCW) from lightly bottomed.Then with the car at a hot (fully warmed up) idle adjust the screws in equal amounts to the highest vacuum.I usually start at driver side primary screw,move onto passenger side primary screw,then passenger side secondary screw and then driver side secondary last.Keep track of how many turns out each screw is.Once you get highest vacuum you can lean them out 1/8 to 1/4 turn.I can't seem to lean mine out any otherwsie I get a tip in stumble.Experimentation will tell you what works for you.I then shut the car off and turn all 4 screws back in and set them all to the leanest screw (least amount of turns on whichever screw) and set all 4 to that number of turns...more or less to equalize all 4.You may need to tweak them a lil after starting it bac up and doing some test driving.This should get you close to optimum.
Old Sep 30, 2005 | 09:50 AM
Confuzed1's Avatar
Car: 83Z28 HO
Just to check in on this post one last time...
The 400 is running better than ever I believe!! It seems to have better part-throttle response. Again, thanks for the help everyone....and especially onebad82z.
Old Sep 30, 2005 | 11:05 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
sounds good!
Old Sep 30, 2005 | 11:35 AM
Confuzed1's Avatar
Car: 83Z28 HO
sounds good!
Wait 'till you get your 400 project together .....You'll love the torque!
I think I'm ready to see how it'll run in 1/4, just to see what it'll do, just for fun!
Old Sep 30, 2005 | 12:01 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I hear ya!
The big upgrade this winter is trying to hunt down an LS1 series T56 trans to swap in.I need a 6 speed.
Then hopefully next winter I can get the 400 in
Get here to the track...it'll suprise ya.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
