need help, 85 IROC 305 carb
Old Sep 10, 2005 | 02:36 PM
jksstar's Avatar
Car: 1985 IROC Z28 and 99 Nissan Altima
Engine: 305 TPI / KA24DE on N2O
I think this is the right place to put this
Heres a vid.
http://videos.streetfire.net/player....2-564F6A61B719
I messed with the timing alittle (not to much, no light) and its alittle better but it is backfireing bad and black smoke, and it dies when I put it in gear.
what ya'll think? I think I may just need a new carb.? I have been told that it is my power valve and others have said that it is just my timing being off. It starts fine and idols(sp?) ok, I'm just dumb at get get it to work
Old Sep 10, 2005 | 07:44 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
If a picture is worth a thousand words, a video is worth even more. That engine is definately running on 7 cylinders. Check plug wires (crossed), plugs and compression. It may have either a broken valve spring or a valve not sealing-off/burnt. Did you just do an intake swap? Greets from Arab, AL.
Old Sep 11, 2005 | 08:51 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
if you have headers you can let it run awhile and drip some water on them just after the flange and if it doesnt boil off than that cylinder isnt running. drip water dont pour it.
that might help. good luck
Old Sep 12, 2005 | 02:36 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Double check all plugs and wires and make sure all cylinders are firing. If the spark check out good on all cylinders, pop the valve covers and make sure all the valves are opening and shutting. Could be a broken pushrod. BTW what is your timing set at?
Old Sep 12, 2005 | 03:26 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Maybe you have the timing retarded way to much? Does in overheat?
Old Sep 12, 2005 | 08:43 PM
jksstar's Avatar
It does not over heat stays inbetween 170 180, not sure on the timing. Have to go get a timing light. I'm going to go at it Tues night one more time and try some things that ya'll have posted.
Old Sep 14, 2005 | 09:53 AM
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
i agree buy a new carb and reset timeing .try a 600cfm holly or eldabroke there both good.or get a 850 like i have on my olds : )
Old Sep 14, 2005 | 10:10 AM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
850 is gonna be way to much for a stock 305. Before you start throwing parts at it I'd make sure you know exactly what it is.
Old Sep 14, 2005 | 09:17 PM
fastfbody's Avatar
Engine: L98 350 tpi
i was kidding
a 850cfm carb would do more bad then good.
Old Sep 14, 2005 | 09:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Certainly isn't running on all 8 properly.
None of those things have anything to do with not running properly on all 8 cylinders - i.e., a consistent miss on every two rotations of the engine.
Go back to Door #1.
Exactly.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Derick15
Sep 17, 2016 05:28 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
