Gas filter
Old Nov 24, 2005 | 10:55 AM
JMJ2003's Avatar
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Gas filter
So I replaced my gas filter in my carb a few nights ago...
I cut open the old filter (I was bored) and lo' and behol' there were metal flakes in it... Since it was shiney, I'm guessin' aluminum...
(And that's what my dad said. Haha!)
Any idea's whats up...
Old Jan 9, 2006 | 09:15 AM
Vader's Avatar
Has the fuel pump been replaced lately?
Old Jan 9, 2006 | 12:08 PM
JMJ2003's Avatar
Car: A beater.
Its the origional one from 1984.
Old Jan 9, 2006 | 01:00 PM
82knightrider's Avatar
Transmission: TH200C....700R4
good idea to get a new one now
Old Jan 9, 2006 | 05:13 PM
JMJ2003's Avatar
Car: A beater.
Do you mean the fuel pump? Or fuel filter??
Old Jan 9, 2006 | 05:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
More likely it's just sediment from the fuel.
Old Jan 10, 2006 | 12:55 AM
JMJ2003's Avatar
Car: A beater.
Would sediment REALLY leave shiney flakes though in the fuel filter?
Old Jan 10, 2006 | 01:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe, if it's fine particles of silica and sand.
Old Jan 10, 2006 | 11:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I wouldn't change the fuel pump unless the car wasn't running. Not a lot of point fixing something that isn't broken.
You changed the filter, so I wouldn't worry about anything yet...
Old Jan 10, 2006 | 02:20 PM
Vader's Avatar
I meant fuel pump.
If the pump had failed, there may be aluminum bits from the old one stuck in the filter, or possibly manufacturing remnants from a replacement left there.
If the pump is original, forget that theory.
Old Jan 10, 2006 | 03:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Do diaphragm pumps make shavings when they fail?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
