what to clean carb with??? Pics inside!
Old Feb 21, 2006 | 12:40 PM
Guest
Guest
Posts: n/a
ok i got a holley 650DP off e-bay last year and as soon as i got it i was pretty happy with it when i took it out of the box that is untill i took the bowls off... i'm the type of person that rebuilts everythign i get for my car when i buy it used so iknow i won't have problems down the road... anyways the inside of the carb was all white can had deposits all over. i e-mailed the guy i get the carb from and he said they only used 100 racing fuel in the carb (maybe part of the problem is that the carb was on a ford ) i have tried just about everything i can think of to try and clean this carb out.. i'm liek to use this carb i mean all it needs is some cleaning i just have no idea what to clean it with... the car is 100% taken apart so i can have the carb in the cleaner over night.. i have tried that B-12 and the gunk carb cleaner some of it came off but not that much. take a look at the pics and you can see what i'm talkign about... this bowl i haven't tried to clean yet (thats why the float is still in it.)
my problem really is that is blocking the passage ways in the metering block and the main body
<p><center>
<img src="http://67.175.172.112/carb1.jpg">
<img src="http://67.175.172.112/carb2.jpg">
</center></p>
Old Feb 21, 2006 | 01:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Try the dip-type carb/parts cleaner. It's got more than just solvents in it.
You may have yourself a nice little FUBAR paperweight.
Old Feb 21, 2006 | 03:06 PM
chesterfield's Avatar
Car: Pontiac
i would try some Naval Jelly if you got some.
Old Feb 21, 2006 | 03:10 PM
jachin85's Avatar
Car: 84 z28
Transmission: ??
Axle/Gears: ??
bead blast it with some walnut shell
Old Feb 21, 2006 | 03:16 PM
The carb is garbage. Every passage, every orifice, is just like that. It's not a matter of "looks". There is not the chance of a snowball in Hell, of that thing ever working right again.
Old Feb 22, 2006 | 04:24 PM
GMguy's Avatar
Car: 96camaro ss,87z28, elcamino,68 firebird
Engine: which car ?
Transmission: most likely a manuel
i would say the guy was lineing an that carb was on a boat that sank or the carb was under water for some time . that what alum an water look like after some time .
Old Feb 22, 2006 | 06:13 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
I have to agree with GMGuy. That is a bowl that has been exposed to water. That isnt any "racing fuel" ran thru that. Unless it was on a hybrid
Old Feb 24, 2006 | 09:16 AM
Damon's Avatar
Agreed- that's corrosion. Not fuel sludge or dirt. That's sucker has spent some time in Davy Jones Locker (underwater) or had some time of totally incompatible fuel run through it (alcohol?).
Race fuel doesn't do that. Unless maybe it's nitromethane or something!
Old Feb 24, 2006 | 10:10 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
well since you can't really return it now, you're basically stuck with it. Might as well try everything/anything you can think of.
Try boiling it on the stove in water/vinegar. It's mildly acidic, so it should clean it well.
Old Feb 24, 2006 | 03:59 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Go to a boat shop and get some barnicle cleaner
Old Feb 27, 2006 | 05:32 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
CLR
Old Mar 11, 2006 | 08:42 AM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
I have been taking apart holly over the last couple of weeks to make a real nice one and i steamed out ever paasege and it worked great if you have a steam cleaner i do mine at work
Infested
May 22, 2018 11:56 PM
qz6lwp
Aug 20, 2015 08:10 PM
Dialed_In
Aug 20, 2015 01:45 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
