stumbling...
Old Feb 26, 2006 | 07:52 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
stumbling...
hey everyone, I thought i fixed the stumble problem with a new filter, but it's back again. I've got a 350 (mods in sig) with a rebuilt CC qjet and CC distributor. The car stumbles like it's running out of fuel, usually in the higher rpms. but, the other day after i had driven the car around town and gave it about half throttle, it stumbled even earlier than it usually does. I've got a new carter fuel pump, but the stock DR/N rods/hanger are in it. any idea on what the problem could be?
Old Feb 27, 2006 | 08:22 PM
84 t/a 5.0's Avatar
any ideas?
Old Feb 28, 2006 | 07:44 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Using stock replacement filter with the small check valve? I always pull the ball/spring out of them.
Old Feb 28, 2006 | 10:27 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Maybe you need new rods...
Old Feb 28, 2006 | 10:39 AM
84 t/a 5.0's Avatar
yeah, it's the stock replacement filter. I noticed a spring in the filter housing, but not a check valve, is that in the filter itself? By the way, it's at 8* advance.
Old Feb 28, 2006 | 01:38 PM
naf's Avatar
naf
The spring and plastic ball is the check valve. You can pull the rubber gasket piece out and dispose of the spring and ball.
Old Feb 28, 2006 | 04:11 PM
naf's Avatar
naf
Sorry I probably wasn't clear. There's a spring and check ball inside the rubber gasket in the filter. You can pull out the check ball then reinstall the gasket in the filter without it.
Hope your problem is as simple as this.
Old Mar 5, 2006 | 02:20 PM
84 t/a 5.0's Avatar
well, i've got a problem. I've noticed when the car is still cold after just driving for a couple minutes, the car rev's fine up to 5k+ and doesn't nose dive. But, after i've warmed it up by driving for a while, it nose dives when i hit around 4k. Any ideas?
Old Mar 6, 2006 | 07:28 AM
84H.O.Trans Am's Avatar
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
when the shop rebuilt the carb did they check the TPS and other electronic sensors on the carb, also is your o2 sensor hooked up and working properly..
Old Mar 6, 2006 | 10:10 AM
naf's Avatar
naf
Unplug your TPS when it's warm and see if there's a difference.
Old Mar 12, 2006 | 01:29 PM
84 t/a 5.0's Avatar
well, seems like i got it fixed. i adjusted the AV to open easier, and now it revs up to 5500 with only a slight hesitation. I think i might file down that tab to let the AV open more. thanks for the help everyone.
Peter
Nov 10, 2002 05:46 PM
