Is 8 degrees ATDC normal?
Old May 7, 2006 | 08:10 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
I plugged in the timing light for the first time in a while after discovering my hold-down bolt was loose. Discovered the initial timing is 8 degrees ATDC. The norm is 8 degrees BTDC correct? My engine seems to like the retarded timing, just curious to see if this is outside the realm of normal. My compression is around 11:1. Any thoughts?
Old May 7, 2006 | 08:21 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
mine motor hates anything less than 10* intial advance
Old May 7, 2006 | 09:46 PM
rjmcgee's Avatar
Do you have a stock dampener? If so the outside ring may be slipping.
Old May 7, 2006 | 10:20 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yes 10' before top dead center is normal, in fact depending on your cam you could probably use even more timing being that you're running a 412ci motor and 11:1 compression. I would look into swapping out weights and springs in the distributor for less overall timing advance curve and running more initial. For instance on my last motor I ran 16' timing advance curve, so initial timing was 20' btdc and 36 total at 3500 rpm.
Old May 7, 2006 | 10:26 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
8 degrees ATDC is NOT NORMAL. Your balancer may have spun the outer ring and be giving you false #s. Most motors will not even idle with less than 0 deg. timing, especially performance motors. You shouldn't have less than 10 BTDC idling.
Old May 7, 2006 | 10:37 PM
xpndbl3's Avatar
Car: 1984 Z28
he said his hold down bolt was loose.....therefore the distributor would have spun around a bit, i do not think that the balancer has spun the outer ring, rather the distributor turned due to a loose hold down bolt.
Old May 8, 2006 | 12:32 AM
rjmcgee's Avatar
There is no way my car will run with the timing at 8* ATDC.
Old May 8, 2006 | 08:46 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
I do have a balancer cover that has the timing marks displayed on the outside.
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
ironbmt
Sep 27, 2015 06:00 AM
