carb hold down bolt torque
Old Jun 18, 2006 | 09:57 PM
Firebird1984's Avatar
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
Ok, this is about as basic as it gets. I did try the search feature and found nothing. In regards to the torque on the carb hold-down studs. Is there a specific torque figure or is it just "snug them down and let it go at that? (this has been my usual routine) I thought I read somewhere that they were to be tightened to 10 ft/lbs, but I can't find it in any of my manuals. It's an Edelbrock Performer on an Edelbrock EPS manifold using carb studs instead of bolts. TIA
Old Jun 18, 2006 | 11:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
sorry, I just snug them down lightly. 10ft/lbs sounds right though, it's a weeny amount of torque.
Old Jun 19, 2006 | 09:58 AM
Damon's Avatar
If you can put a screwdriver type handle on the end of your 1/2" socket then tighten it that way.
Old Jun 19, 2006 | 10:08 PM
Thanks guys, I appreciate the replies. I guess I never stopped to think about a specific torque spec. Since I'm working with all new parts, I've become overly cautious about overtightening and warping things. Guess I'm getting paranoid in my old age! Thanks again!
Brad
PS- I like that screwdriver handle idea!
Old Jun 20, 2006 | 03:38 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I usually get either a really stubby socket wrench, or turn the wrench by rotating the "head" rather than the way you're supposed to.
Old Jun 20, 2006 | 05:57 PM
EvilCartman's Avatar
Car: '82 Z28
Think I read it as 10 INCH pounds not foot pounds.
Old Jun 20, 2006 | 10:19 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
yeah 10 foot pounds is going to warp something majorly.
Old Jun 21, 2006 | 12:46 PM
99Hawk120's Avatar
No, actually 10 ft-lbs sounds about right. You can try 10 in-lbs if you want, but you'll probably never get the base gasket to seal, especially if it's new.
Old Jun 21, 2006 | 11:05 PM
Car: '82 Z28
Well I had to go digging on what it would be. Holley recomends 60 inch lbs or 5 foot lbs on their carbs. Don't have a Haynes or Chiltons in front of me to look up stock specs to see if it's any different.
Old Jun 21, 2006 | 11:10 PM
99Hawk120's Avatar
1984 Olds Service Manual
Carburetor to Intake Manifold Bolts 14 N-m 10 ft-lbs
I highly doubt any other QJet is going to be different, certainly not any of the 170xxxx series.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Dialed_In
Aug 20, 2015 01:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
