Yikes, just made a discovery
Old Sep 22, 2006 | 02:01 AM
EvilCartman's Avatar
Car: '82 Z28
I just replaced the gaskets for the float adjustment nut and screw on the speed demon when I found a shot of fuel coming from the rear accelerator pump arm Noticed fuel down on the intake but thought that must have been from one of the gaskets just replaced. Going to take it apart to check it out. Drove the car for a couple days last weekend so I'm glad it didn't catch a spark.
Old Sep 22, 2006 | 03:24 AM
Car: '82 Z28
Meh, looks like it was just the 4 screws holding the pump housing not tight enough. Took it apart and checked for any slits in the diaphram and it looked good. No leaks after putting it back together yay.
Old Sep 22, 2006 | 06:57 AM
Ironmahn's Avatar
Car: 1986 Trans Am
Old Sep 22, 2006 | 02:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you have a fire extinguisher in the car right?
Old Sep 22, 2006 | 04:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I bring marshmallows
Old Sep 22, 2006 | 09:46 PM
Car: '82 Z28
What are those? I have a nice big one in the shop and a couple in the house but none in vehicles Did have my nomex fire jacket though
Old Sep 22, 2006 | 09:48 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
trying to ruin all that hard body work already huh? haha
Old Sep 23, 2006 | 03:16 AM
Car: '82 Z28
Of course! If I were to get an extinguisher, I'd rather get the halon type instead of dry chem (corosion factor if used). Expensive little buggers though I guess they're cheep compared to replacing a car though.
Old Sep 23, 2006 | 08:10 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
just make sure you get out of the car before using it though... halon will suck the o2 out of a fire, and you lungs too if you're in a confined space. why they put then in small private general aviation aircraft, i don't know...
Old Sep 23, 2006 | 03:01 PM
Car: '82 Z28
They want to make sure that everything and everyone is "out" hehe.
Old Sep 23, 2006 | 04:16 PM
Car: 1982 Trans Am
Engine: 383 chevy
LOL... that's so wrong...
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
dusterbd
Sep 29, 2015 08:40 AM
