Intake/carb combo needed!!
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
ok motor will hopefully be back together soon and i need a non cc carb and better intake cam makes power from idle to 5500rpm im running true dual hedman lt into 2 1/2 H then Flowmaster 10series dumped. im ditching computer i can get a vacume dizzy just need sugestions on what intake/carb to get. rem its a 305 so bare with me. im also not planing on spending a lot in thissetup just need something to work well and be on the cheap side
thanks!
thanks! Joined: Mar 2000
Transmission: 4L80E/4L80E
I don't see anything that says you need anything different from the stock setup. You could go with a Performer or Action + intake, but they aren't going to make that much difference, and will cost more than just keeping the stock pieces.
Car: 1987 TA
Engine: 350 stock/twecked
I agree with the last post.
use an eldrbrock 1406. get some 1.6 rockers a little bit of cheap hp 10 or 15 peak no much but for $60 thats cheap hp. The rockers will cost less than a manifold and be more benifical to your motors breatability.
your set up is basicaly stock so keep it that way on the manifold. I got a stock roller 305 in an elky witha lt1 cam and a 1406 elderbrock carb, 1.6 rockers and it reves to 6000 rpms. not smart but fun
later and
gb
later and
gb
so just find a carb and i should be good then and mabsy some 1.6rockers alright. what size carb should irun?
Car: 89 Firebird
Engine: 383 stroker 11 to 1
Transmission: th350
Axle/Gears: 3.73 posi
I've got a Performance Products manifold and a Holley 600 vac sec, electric choke. Whole setup has about 500 miles on it. Moving up to a non streetable setup. Looking for 1/2 what I paid new for it. dmason@mckennapro.com
Screamin, I'll repeat my original response: The stock CC carb will do you fine. Why do you want to put on something that will cost you money and provide zero performance improvement?
A Performer carb replacing a stock carb would be a serious mis-spending of performance $'s.
i ran my cc carb/intake for awhile and i had nothing but problems plus not having a non computer compatable cam didnt help. im getting rid of the computer adn unneed wireing all together thats why!!!
Always nice to know the "whys".
(Still wouldn't go with the Performer, though...)
well i might just get ahold of a non cc q-jet from a friend and rebuild it and run it since i have more experiance with them and i can get a few for free that need rebuilt luckly ive got some friends that can work on them and i rebuilt two for my t/a before
IMissMy86TA
Aug 31, 2015 08:40 PM
