Choke problems
Old Dec 31, 2006 | 02:29 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Choke problems
I recently rebuilt my Quadrajet. It is an earlier model, (non-CCC). I used the electric choke off of my CCC, (original was heated) and I was looking at the functionality of it. I was told that some electric chokes open in the opposite direction. I looked at mine, and it seems that the element would close the choke when warm. (I could be wrong). I removed, and flipped over the spring element in choke, and now the choke won't stay closed. What's wrong here? Am I wrong.
Is there any online tut that shows diagrams, and tells about it's function?
Yes, I have done a Google search, and searched the boards.
And I have the Haynes manual, but it's in storage now.
I checked All Data, but it doesn't really say much aobut that.
Thanks for your help in advance.
Old Dec 31, 2006 | 12:14 PM
novatuc's Avatar
Car: 1984 Trans Am
The coil is only to open the choke back up after it is warm. It is closed mechanically.
Old Dec 31, 2006 | 12:29 PM
stingerssx's Avatar
I understand that but the choke flap stays open on it's own. What "mechanically" closes the choke?
On the heated choke, the coil opened, and closed the choke. But on the electric choke, the coil only pushes the choke one way.
Does any one have any exploded veiws, or pictures of how the choke is suposed to work?
Old Dec 31, 2006 | 05:09 PM
stingerssx's Avatar
Ok, I found out how the choke is supposed to work. So I took the choke apart and returned everything to the way that it came. When I installed it, I adjusted the choke closed with tension on the flap. The car wouldn't idle, and was hard to start, and smoked like a chimney. So I relieved tension on the flap and it idles good. The car runs great now. Is this ok?
Old Jan 1, 2007 | 04:35 PM
novatuc's Avatar
Car: 1984 Trans Am
If the car runs great then I think you have your answer. If it starts good and runs good then it's good.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
