is there any alternative?????????
Old Jan 17, 2007 | 09:35 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
is there an alternative to the cc quadrajet besides rochester??????
theres gotta be something.
Old Jan 18, 2007 | 12:06 PM
Why?
There's not. Not at least, if you have to retain the computer control.
Old Jan 18, 2007 | 01:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you want a CC carb, there is no alternative (except for aftermarket rebuilds).
If you want CC/EST ignition, theoretically you could hook up an external TPS to a non-CC carb and "fool" the ECM into thinking it's a CC carb. But, nobody has reported having successfully done that to my knowledge.
Old Jan 18, 2007 | 03:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its been done with the TBI ECMs. Retain the ECM and run a carb in place of the TBI. Theoretically, all youd have to do is substitute a resistor network (or an actual TPS) for the TPS and fool the ECM into thinking the throttle is always open. It should be able to work properly (SA wise, anyway) so long as teh MAP and all other sensors external to the carb are maintained.
Old Jan 18, 2007 | 08:01 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
just rip all the computer crap out, all the wiring, throw an edelbrock on there, get a full MSD ignition setup or HEI, and last but not least a painless wiring harness.. costs about carb=$250, MSD ignition=$600-$700, Painless wiring harness=$400, Labor=FREEE dont be a lazy *** and do it yourself, its PAINLESS
BTW, this is what i did
Old Jan 18, 2007 | 09:53 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Why would you need to buy a $400 new harness to not use the computer?? You just take all the wires coming from the passenger side and not use them.
Old Jan 18, 2007 | 09:56 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
And don't forget to take out the pesky check engine light bulb.
Old Jan 18, 2007 | 10:34 PM
five7kid's Avatar
Originally Posted by 5678TA
...throw an edelbrock on there, ...
Ewww!!!!!!!!!!!!!
Old Jan 19, 2007 | 02:49 AM
5678TA's Avatar
Car: 1984 Trans Am
well when i was restoring my car, it caught on fire and i had to trash the factory harness.. i have no experience with the factory harness, so i just said replace it..
Originally Posted by five7kid
Ewww!!!!!!!!!!!!!
i only said edelbrock for gas mileage.. i dont know what this guy wants out of his car.. and i have a mighty demon myself.. edelbrocks dont really work well with 260* duration.. @.050".. i had good mid-high range power (w/ highest jets available) but low end sucked ***.. with the mighty demon, i have power all around..
Old Jan 19, 2007 | 04:49 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
any carb will give you the same gas milage as long as its built the same (jetting and cfm airflow etc) edelbrock is junk imo (carbs at least), ive never used one but thats all i hear about them and ive tried to tune a friends car with one and that was a waste of time, i've used only holley and they never failed me. but anyways back to the topic...just remove the computer stuff, throw an HEI dist and a holley on it and call it a day
Old Jan 19, 2007 | 10:29 PM
five7kid's Avatar
Keep the CC carb, run just as well, and use your money for things that make a difference.
Old Jan 20, 2007 | 08:54 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well said
worry about more important things
unless you have lots of cash laying around to burn or lot of time on your hands, etc
otherwise youll just get yourself into a mess
most likely
good luck
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
