670 or 770
Old Feb 14, 2007 | 06:12 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
670 or 770
wondering what carb would be better for my application, im going to run either a holley 670 SA or 770, now here some specs on the engine,
-96 vortec block 4 bolt main
-cast crank
-vortec PM rods
-Speed pro .030 over forged aluminum pistons
-Moly rings
-Comp cams hydraulics roller cam .510/.520 lift 282/288 advertised duration
-factory lifters
-double roller timing set
-Aluminum Heads 64cc chamber 190cc intake runner 2.02/1.60 valves(manley valves)
-986-16/742-16/611-16 springs retainers and keepers
-edelbrock torker intake w/ 1" carb spacer(phenolic)
im hoping the engine is around 450hp with all the other goodies i have planed which menas i think it would probaly like the 770 better. what do you guys think????
let me know what else you needs to know
Old Feb 14, 2007 | 07:49 PM
91L98Z28's Avatar
Car: Z28
if this is purely a street car, I'd probably lean to the 670/650. If you intend to go to the track once in a while, then probably the 750/770 is more in your range.
Old Feb 14, 2007 | 08:28 PM
Car: 1979 Malibu
Engine: Blown LSx
it is going to see alot of track time and hopefully somewhere in the 6000 rpm range!
Old Feb 15, 2007 | 01:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by 1986Z28OWNER
wondering what carb would be better for my application, im going to run either a holley 670 SA or 770, ...
Neither. The SA line is a cruel joke on the unsuspecting and unknowing.
Go with a 750 Holley double pumper. If track only, get the HP version. Otherwise, a standard universal 4150 will be fine.
And dump that Torker intake. Another cruel joke. An RPM Air Gap will leave it in the dust. If you want single plane, go for the Victor Jr.
Old Feb 15, 2007 | 01:41 PM
Car: 1979 Malibu
Engine: Blown LSx
dont want a DP, i want VS which any DP dosnt have, running the torker because i got it for free from my dad, and im trying to keep a budget with this car as im only 17. will look into victor jr though
Old Feb 15, 2007 | 04:04 PM
five7kid's Avatar
...i want VS...
Why????
Old Feb 19, 2007 | 03:52 PM
EvilCartman's Avatar
Car: '82 Z28
What are you screwing around with vacuum secondaries for if it's going to see a lot of track time? Get with the program and go with a 750 double pumper
Old Feb 25, 2007 | 09:10 AM
chilli's Avatar
Never thought I would hear someone wanting to build a streetable track car say that they wanted vac secondaries, ewwww!!
Old Feb 25, 2007 | 01:49 PM
dirt_kx's Avatar
Old Mar 16, 2007 | 11:31 AM
Car: 1979 Malibu
Engine: Blown LSx
ok.. so i got a regular 4150 DP, but i need a intake now, Victor jr is going to be to big of a manifold for this engine, any suggestions BTW needs to be a tall port manifold
Old Mar 16, 2007 | 02:19 PM
five7kid's Avatar
Not sure what you mean by "tall port". The Torker isn't anything special. What heads are those, exactly? Edelbrock RPM? Etec?
Old Mar 16, 2007 | 02:40 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
tall port?? you only have 190cc intake runners.. if you need a tall port manifold, port a vic jr to match.. just get the cheapest one and port that guy.. the cheap one has relatively small ports from edelbrock.. i took out a good 1/16th inch all the way around and still didnt match up to a 1205 gasket.. and i use a 1206 gasket.. thats a tall port..
Old Mar 16, 2007 | 05:52 PM
Car: 1979 Malibu
Engine: Blown LSx
the heads are described as having a raised port design and that most regular manifolds won work(if that makes any sense??????)
Old Mar 16, 2007 | 05:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which heads are those, exactly?
Old Mar 16, 2007 | 06:04 PM
Car: '82 Z28
Edelbrock RPM air gap if it'll work.
Old Mar 16, 2007 | 06:06 PM
Car: 1979 Malibu
Engine: Blown LSx
pro comp's 190cc 64cc chambers, 2.02/1.60 valves, straight plug
Old Mar 17, 2007 | 12:16 AM
five7kid's Avatar
Like these, right?
Use a Vortec intake. "Raised" port is more like it.
MyRedCamaro
Dec 29, 2015 05:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
86CamaroDan
Sep 29, 2015 10:08 PM
makaveli09
Sep 15, 2015 10:43 AM
transamgta87
Sep 1, 2015 07:07 PM
