Help! Car Hesitates
Old Mar 6, 2007 | 09:28 AM
eruk's Avatar
Car: 85 iroc, 96 z28 ss, 03 Silverado
Engine: 305, lt4, lingenfelter ls2
Axle/Gears: 3.08, 3.73, 4.10
Help! Car Hesitates
I have a 305 with a Quad. its a older one from the 70's. So it does not have electic choke on any of that stuff. Also it doesnt have vacum lines for the emission crap. Anyway when i get on the gas from a stop it will do nothing for about 5-10 sec and then it will take off slowly until the rpm get to about 1500 and then it will drive normally.
Old Mar 6, 2007 | 10:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What distributor are you using?
What did you do with the choke mechanism (butterfly, etc.) that are on it?
Old Mar 7, 2007 | 09:26 AM
eruk's Avatar
The dist. is stock. The butterfly is there but it is manuel choke, but i dont feel like runing the crap for it. It is only for a while till i get my 350 done.
Old Mar 7, 2007 | 09:21 PM
five7kid's Avatar
A stock distributor uses the ECM to determine ignition timing advance. With a 70's carb, the ECM won't have the information needed to make proper advance decisions. Therefore, it goes into "limp home" mode with next to no advance.
You need a distributor with vacuum and mechanical advance in order to run that carb.
Have you tied the choke open in some fashion or another?
Old Mar 9, 2007 | 09:41 AM
eruk's Avatar
I dont think that is the problem. It runs fine after i get it going. Also if i dont stop all the way it wont have a problem. i can just press the gas and get going right away.
Old Mar 12, 2007 | 07:07 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
As stated above, your stock distributor's ignition advance is controlled by the ECM and because you've switched carbs it is no longer receiving a throttle position reading to tell it to advance. When this is the case it will cause EXACTLY the conditions you describe above.
I will not go so far as to say that this is your ONLY problem, but it is definitely a major issue and should be remedied.
Old Mar 12, 2007 | 09:40 AM
eruk's Avatar
I figured it out. I had a wire loom break a a wire got burnt. Now it runs fine. No hesitation at all. Thanks for all of the sugestion though.
Old Mar 12, 2007 | 09:57 AM
naf's Avatar
naf
If you're using the stock dist (without vacuum and mechanical advance) you'll still get better performance by swapping to a dist designed to run with your mechanical carb. Of course, the dist could have been swapped for an older style when the carb was swapped. The stock style dist will not have the vacuum can on the side with a vacuum line connected to it.
An older style HEI with vacuum advance can be had for under $100 and will probably pay for itself with increased mileage fairly quickly. Both will swap over to a 350.
Let us know what you've got.
Old Dec 22, 2013 | 08:42 PM
casson4's Avatar
Car: 1985 camaro berlinetta
Engine: carb'd lg4 305
Axle/Gears: 3.08's sonn to be 3.73's
Re: Help! Car Hesitates
what wire got burnt cause im having the same problem
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
