Carb Idle
Old Mar 17, 2007 | 01:35 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Carb Idle
Ok so i can't figure out why my Q-Jet is Idling to high. It runs around 2500 rpms. A lot of people say that it is a vaccum leak but im not sure. The other day I was checking it out. Fumes are coming out the exhaust, like excess gas. Is it possible that it is just running too rich, so it is idling fast?
Old Mar 17, 2007 | 03:23 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
vac leak or the choke could be stuck partially on causing the high idle cam to engage.
Old Mar 17, 2007 | 06:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is your choke opening?
Old Mar 17, 2007 | 07:34 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
fumes ? too much fuel ? do you have the E4ME or a non ECM carb or ?
is the choke fast idle screw turned clockwise too much ? is the choke cam weight down all the way ?
make sure the chok is open yes
Old Mar 19, 2007 | 08:46 PM
WaltB_FB92's Avatar
Car: Pontiac Firebird
Engine: V-8 305
Transmission: Automatic 4-speed
Axle/Gears: non posi
Check your springs and levers for grime and dirt
Old Mar 21, 2007 | 05:11 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Re: Carb Idle
What should the timing be on an 86 Iroc 305 4bbl?
Old Mar 21, 2007 | 05:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Factory spec is 0 degrees (TDC) at idle with the flat 4-wire connector from the distributor base to the firewall harness disconnected.
Old Mar 21, 2007 | 07:33 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Re: Carb Idle
but i thought that there is usually an offset on most cars. Not TDC. maybe a little more or a little less. U know?
Old Mar 21, 2007 | 11:16 PM
five7kid's Avatar
We have a very unusual car.
If you like I can go out and take a picture of the emissions decal under the hood. Yours probably has it unless it has suffered a catastrophic event.
If your EGR valve is operating properly, you can probably give it as much as 6 degrees BTDC base with no ill effects.
Old Mar 22, 2007 | 06:44 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Re: Carb Idle
thanks
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
billybob6110
Sep 24, 2016 09:50 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
