Air assembly questions
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
on my 86 305 4bbl firebird i wanna change my air assembly to a K&N http://www.knfilters.com/search/prod...x?Prod=60-1640
i was looking at the factory assembly and theirs alot of tubes connecting to it...theres a tube on the left side i think goes into the valve cover...on the other side its conected to the headers
so my question is what do i have to do to put in the K&N
thanks for bearing with me
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Air assembly questions
The one tube that goes into the valve cover generally goes into the manifold, not the Air Cleaner. This is your PCV valve hose. Not sure what the tubes going to the headers are for.
Is it a snorkel setup you have on top of the intake now? I know on the TBI cars theres a few lines going to that, is this what you mean?
Engine: 305 5.0 LG4
ya its the snorkel setup..i'll take a couple pics to show u what im dealin with
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The factory air cleaner has the snorkel, heat stove pipe for the thermac valve, vacuum line for the thermac valve, and the PCV filter breather hose.
Engine: 305 5.0 LG4
are all those things absolutley needed cuz i really wanna put a k&N on it but it dosent seem possible right now with all this
Engine: 383 Carb
Transmission: 4L60
The K&N air cleaner you're looking at doesn't have a snorkel or thermac valve, so you don't need anything associated with either of those. I believe it has a fitting for the PCV breather hose.
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Sep 7, 2015 01:37 PM
