Conversion from tbi to carb nearly complete (vid)
Old Jun 11, 2007 | 10:33 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Took this video today. I thought I wouldn't get the car back together but it's turned out pretty good I think. Trying to link to UTUBE.
http://www.youtube.com/watch?v=GKr-PPGkNFo
Old Jun 11, 2007 | 11:02 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Conversion from tbi to carb nearly complete (vid)
It's sounding good man, hope it all turns out well for you.
Old Jun 12, 2007 | 01:04 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
sounds really nice which fittings and lines did you use for the ps pump?
Old Jun 13, 2007 | 11:03 AM
pondriver's Avatar
Engine: 350 HSR
I just cut the ends off the cooling lines and had them brazed to some -an fittings then had the lines made up at a local industrial supply house.
Old Jun 19, 2007 | 10:54 AM
IROCZ_L98's Avatar
Car: 1987 IROCZ
Engine: 355, Vortec Heads, Carbed
Transmission: TH350, 2800 stall
Axle/Gears: 3.27 9 Bolt
Sounds really good, what do you have as far as exhaust goes?
Old Jun 19, 2007 | 11:51 AM
pondriver's Avatar
Engine: 350 HSR
I just had a mufflex y-pipe on at the time. I don't really like how it fits. I'm not sure what path I will take.
Old Jun 19, 2007 | 12:41 PM
BlueSmoke's Avatar
Car: 91 RS Camro Ttop
Engine: 5.0 LO3
yep love that sound. looks sweet too, alot nicer looking than tbi. What size carb is that?
Old Jun 19, 2007 | 01:52 PM
pondriver's Avatar
Engine: 350 HSR
Holley 770 Street Avenger. Hoping it won't be too big.
Old Feb 2, 2008 | 10:22 PM
Stephen's Avatar
Car: 87 GTA
Long tubes or shorties? Sounds GOOD!
Old Feb 2, 2008 | 10:58 PM
pondriver's Avatar
Engine: 350 HSR
Hooker Long tubes
Old Feb 2, 2008 | 11:43 PM
Stephen's Avatar
Car: 87 GTA
I suspected long tubes. Shorties can never match the sound.
I getting it was running out of the Y-pipe then?
MustangBeater20
Oct 29, 2022 09:20 PM
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
