throttle position sensor
Old Jul 31, 2007 | 02:06 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
dose someone make a throttle position sensor for a proform main base carb.
i am thinking of buying a lm-1 with the lma-2 rpm converter. since they can log a wide band o2, the rpms, and 4 other sensor, i thought 2 good ones to help tuning would be a throttle position sensor, and a map sensor.
Old Jul 31, 2007 | 03:09 PM
z28z34man's Avatar
Re: throttle position sensor
if one doesnt exist this is a ruff diagram of how it would be made
the pot has to be a 1/4 turn pot and connected to the primary throttle shaft somehow
Old Jul 31, 2007 | 03:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd have to improvise something. Look for a thread started by five7kid, he's managed to put a TPS on a Holley carb. The idea should be similar.
Old Jul 31, 2007 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since the thread title isn't all that clear. . .
https://www.thirdgen.org/forums/carb...cant-done.html
Old Aug 1, 2007 | 10:05 AM
z28z34man's Avatar
where did you get the 5 volt one, because i need one that ranges from 0-5 volts
Old Aug 1, 2007 | 10:36 AM
five7kid's Avatar
5 volts is the power to the TPS. The output is dropped by the TPS until you get to WOT.
To be honest with you, I'm not sure I've got it right yet. I can adjust mine to the proper .46 volts at idle, but I'm only getting 3.7 volts WOT. It seems to run okay, I'm just not sure I'm getting full advance out of the ignition.
Work in progress. . .
Here's the link Vader posted back in the day that got me started: http://www.becontrols.com/tech/tpsretro.htm
Old Aug 1, 2007 | 12:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you getting full travel out of the TPS? Adding a couple of pots would give you an adjustable span and offset.
Old Aug 1, 2007 | 01:09 PM
five7kid's Avatar
No problem with the travel. I used a spring, and it gets the TPS to full stroke about half way into the secondary opening.
Old Aug 1, 2007 | 02:11 PM
z28z34man's Avatar
it the hot side connected directly to a switched 12 volt source or do i have to make a voltage divider bias
Old Aug 1, 2007 | 03:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In five7kid's application, the ECM is providing him with a regulated +5V reference. You'd need to provide a regulated source of your own, a voltage divider isn't really going to be suitable.
Old Aug 2, 2007 | 10:22 AM
z28z34man's Avatar
how about a 5 volt zener diode
Old Aug 2, 2007 | 11:38 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could. This is such a low-current application that a zener would be ok.
Old Aug 2, 2007 | 12:14 PM
five7kid's Avatar
Upon further review, probably not true.
Plan on fiddling with it this evening. Will post results then.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
