cable attach point.....
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
guys...could you post photos of how the throttle cable is attached to a holley carb? the carb has the typical holley throttle arm with the ball attach point. how does the slotted throttle cable end get attched without it falling off? need pictures!! thanks
Transmission: 4L80E/4L80E
https://www.thirdgen.org/forums/carb...cant-done.html
Check the pic in post #2.
The slotted one is the cruise control cable.
Re: cable attach point.....
You can either buy a throttle cable that matches the carb, or buy a ball stud that matches your cable. Your call, whichever you can get easier & cheaper.
at present i've just got a bolt that's screwed into the throttle lever...just doesn't look professional....
Here's a little better picture of my latest arrangement.
Still not sure what you mean by "slotted".
five7kid...is that a 600cfm on a 350? how's it run? what cam? vac. sec.'s?..i've got one, but i thought it would be too small for a 350....thanks sofakingdom....
That's a Holley 650 CFM double pumper 6210 spreadbore. The throttle arm is identical to the 4776 650 DP I have on the 396 (although nothing much remains from the 4776). I used a Summit corrector bracket for the TV cable.
Engine details in sig.
Running it with a CC distributor, by the way. Not sure if anyone else had done that yet.
wigmobile
Feb 26, 2025 02:56 PM
