Foam Breathers?
Old Jan 11, 2008 | 11:10 PM
Firebird_dave7's Avatar
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
Foam Breathers?
Where do i get a foam Air Filter, or who makes them?
Hear they breathe alot better and noticable gains in get-up-n-go. So help me out please.
Old Jan 12, 2008 | 02:03 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Foam Breathers?
am using a K&N; they claim extra hp benefits. personally don't really run fast enough on the way to work and back to care about extra breathing, but sure is nice being able to clean, reuse.
Old Jan 12, 2008 | 12:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
AMSOIL used to make them, but they've gone to a different, non-oiled type due to MAF problems that can occur with oiled filters.
I believe Accel makes an oiled foam filter (although I can't find it on Summit now). You don't want to use a non-oiled type.
K&N's flow well, but they let a lot more dirt through them than a standard paper filter. They're basically an expensive way to wear out your engine more quickly.
If you want a good flowing, good filtering, cleanable filter, look into the AMSOIL Ea series. http://www.amsoil.com/StoreFront/eaa.aspx
Old Jan 12, 2008 | 04:15 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Foam Breathers?
Precisely - they flow more, because the holes are bigger.
Paper filters are still best IMO - carb or EFI - they are dirt cheap and they don't cause any problems like the oiled filters can (they can gum up MAF sensors and if it gets bad enough, sometimes even passages in the throttle body of a carb).
Old Jan 12, 2008 | 04:20 PM
five7kid's Avatar
Paper has been one-upped by the AMSOIL Ea filters. Since the fibers are finer, you can have small holes to stop the dirt, but more of them to allow more air in.
Oiled foam is fine if you don't have MAF. It works on a different principle, but a good one.
Old Jan 12, 2008 | 08:07 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: Foam Breathers?
I searched on K&N & saw what you are saying. crud. it's probably getting to my car. good thing I don't live in a place known for dust like Vegas (have you seen the billboards there that say "don't drive through dirt & kick up dust"?).
K&N says 96% and 99% efficiency http://www.knfilters.com/efficiency_testing.htm
IIRC a cigarette ash is about 10 microns
so how small a particulate are AMSOIL filtering down to?
Old Jan 12, 2008 | 08:46 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Re: Foam Breathers?
Five7, are you referring to a particular foam filter produced by K&N letting in alot of dirt or their filters in general? I've been using a K&N 3" element for 3 years. Yikes! Jon
Old Jan 13, 2008 | 11:19 PM
five7kid's Avatar
I'm referring to K&N's oiled gauze filters.
Old Jan 14, 2008 | 10:52 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: Foam Breathers?
I'm using the K&N oil spray filter... so say some 5 micron pieces of grit get sucked passed the air filter, mixed with fuel, sucked or squirted into 8 chambers, compressed, tossed around during a contained explosion, then that grit either ends up getting sucked out w/ exhaust fumes or gets stuck to our engine oil. guess it take about maybe 10 or 15 minutes for 100% of engine oil pass to through the oil filter? from reading the results of the K&N test data, having 5 micron grit in our cars is a likely case. How much damage is going to occur to our engines?
Old Jan 14, 2008 | 11:21 AM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: Foam Breathers?
dont buy the edelbrock foam ???-flo. 1 backfire and its melted
Old Jan 14, 2008 | 12:00 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Re: Foam Breathers?
I had the same problem on my Toyota Celica, the oil from the filter clogged the sensor and it ran like hell. And on my old Jeep, you should have seen the dirt on the throttle body from oil build up and me driving off road.
No more K&N for my cars thats for sure.
Old Jan 15, 2008 | 02:31 AM
five7kid's Avatar
A lot, actually.
Old Jan 15, 2008 | 06:41 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: Foam Breathers?
argg! well, I see an upgrade coming...
Old Jan 16, 2008 | 08:18 PM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
Re: Foam Breathers?
The local sherriff's dept had to put mine out! Man was I pissed. And no Edelbrock wouldn't pay for a new Holley carb or even buy me a rebuild kit for that matter. Never again will I use that pos Edelbrock pro **** air cleaner. It's suicide!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Pac J
May 17, 2020 10:44 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
sleprock
Sep 24, 2015 04:33 PM
1985chevydude
Aug 20, 2015 12:29 AM
