open element air cleaner question
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
hey guys-
those of you who use open element air cleaners, what brand (part # if possible) and size do you use? also, what do you do with the breather hose that goes into the stock air cleaner?
i have a 1983 bird LG4 w/ quadrajet
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Re: open element air cleaner question
goto your local checker or orielys and grab what ever spectre, holley or edel brock 14" they have on hand, they should fit fine, upgrade to a good filter and your set
i was looking at this:
http://store.summitracing.com/partde...376+4294756361
it should fit but will it have enough clearance for the edelbrock TBI/carb STB?
Transmission: 4L80E/4L80E
You're asking questions about things not normally done. If you've already got the STB, do some measuring for yourself.
Sorry, but sometimes you just need to do the footwork yourself.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/atta...b-dsc00010.jpg
JamesC
Car: 1987 Camaro
Engine: 5.7
my friends 89 rs has the edelbrock STB and open element cleaner and it all fitted fine with stock hood.
Also for the think in the valve cover to the aircleaner, just get a valve cover breather and stick it in there.
86IROC112
Sep 7, 2015 01:37 PM
