replace Q-jet?
Old May 12, 2008 | 07:00 PM
bbatton's Avatar
Car: 86 Camaro
Transmission: 5 speed
replace Q-jet?
I rebuilt this q-jet ccc and it just seems like it still isn;t running right. My question what type of carb can I replace with it without replacing anything else?
Old May 12, 2008 | 07:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Another CC q-jet.
Old May 12, 2008 | 07:51 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: replace Q-jet?
What are the symptoms?
Old May 12, 2008 | 08:12 PM
bbatton's Avatar
Car: 86 Camaro
Re: replace Q-jet?
I can get up to around 45 mph and then press on the gas and just seems there is no power.
I might just tear down the carb again and go back thru the steps of rebuilding it.
It is really hard to start also once it's cooled down. And when it does start I have to keep the pedal pressed or it will die but once it gets warmed up it will stay cranked but has rough idle to it.
Originally Posted by five7kid
Another CC q-jet.
I'am no expert on carbs, but does edelbrock make a CC carb that will work?
Old May 12, 2008 | 08:38 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Re: replace Q-jet?
Rebuilding a q-jet isn't a quick and easy thing to do, there are many details you have to be aware of. Clearly when you rebuilt it the first time, something was overlooked. So far as any other manufacturer making a replacement for the computer controlled carb, unfortunately, no. Holley does make a quadrajet remanufactured carb using a refurbished q-jet carb with all new and clean workings.
Old May 13, 2008 | 02:43 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: replace Q-jet?
I only use Holley carbs, other will argue differently but i have no issues with tuning and rebuilds are a snap.
Old May 13, 2008 | 11:29 PM
five7kid's Avatar
No. Nobody makes a replacement CC carb.
Old May 16, 2008 | 02:41 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: replace Q-jet?
Holley do a refurbished cc qjet available through summit,or try (sean murphy induction).he does them as well.
http://smicarburetor.com/products/?s...ID2=9&sfID3=34
Old May 16, 2008 | 12:17 PM
Kevin84Z28's Avatar
Re: replace Q-jet?
Good info, but it's still a rebuilt Qjet, not an aftermarket version of the same.
Old May 17, 2008 | 02:51 AM
alicat's Avatar
Axle/Gears: Stock.
Re: replace Q-jet?
I know he's looking for a new replacement for it.Just giving him a heads up on rebuilt one's,since you cant get new ones,although some people can almost rebuild them to that point.
Old May 17, 2008 | 10:03 AM
Kevin84Z28's Avatar
Re: replace Q-jet?
I agree, it's very hard to find a good Qjet replacement. If you look in most parts catalogues they might have one Qjet, usually for a 60's or 70's GM. It's hard to find a well built Qjet with a warranty.
Old May 17, 2008 | 02:30 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: replace Q-jet?
I have a CC Q-jet I took of my 82 in 82. It has less then 500 miles on it. Not sure if anyone is interested in it? Send me a message if your interested.
Old May 30, 2008 | 10:14 PM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
Re: replace Q-jet?
I had similar problem, I think engine rebuild and reman carb will fix the problem.
I've got my carb here http://www.carburetorsusa.com/
I would say not bad rebuilt for ccc
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
