carb fuel pressure
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
carb fuel pressure
how much fuel pressure do you need with a carb?
I have this fuel pump http://store.summitracing.com/partde...5&autoview=sku and I am thinking the pressure is to high. The car runs really rich and no matter what I do it dosent seem to change. I have a 1406 edelbrock 600 carb, I got the calibration kit and put leaner jets and metering rods in and it still runs really rich
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb fuel pressure
You shouldn't normally use more than about 6 PSI or so with a carb.
Car: 1982 Trans am
Engine: 383
my fuel pump is rated for max 7.5 psi, would the extra 1.5 psi make that big of a difference?
Car: 1982 Trans am
Engine: 383
I've had this regulator in my tool box for a few years, I think my dad gave it to me, anyway will it work with a carb? and how do you adjust it or is it even adjustable?
I tried to look up the numbers on it and I didn't find anything.
the numbers are 34r-6657B and 446
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Looks to me like if you tighten down the stud on the opposite side of the in port it should lower the fuel pressure.
By running rich do you mean at idle or driving? If at idle, then screw in the two screws some on the front that have springs on them. If it's rich driving, might try taking the top off the carb and adjusting the floats so the fuel level is lower. Also, I was running around 8psi last year with my carb just fine.
Car: 1982 Trans am
Engine: 383
Thanks, I am gonna hook it up tomorrow, hopefully it solves my problem.
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
looks like the little carb type. adjuster is the locknut and threaded bolt on top. you will need a guage too, to see what you've got. but check the summit website for the number on the reg, if its not a carb type you could ruin the carb with too much pressure.
Car: 1982 Trans am
Engine: 383
I already tried summit, couldn't find anything. I've been running it without a regulator for awhile the pumps only rated at 7.5 psi
Transmission: 4L80E/4L80E
You don't need a regulator with that pump. If you want to put that regulator in, it'll be fine. You adjust the pressure on it by loosening the lock nut, and turning the "stud" in to raise pressure, out to lower pressure, using a gage to quantify the pressure, then tightening the lock nut.
Did your car originally have a carb, or crossfire?
When is it rich? Idle? Cruise? WOT? How do you know it's rich? Are the floats adjusted properly? Do you have a filter before the carb inlet?
Car: 1982 Trans am
Engine: 383
yes I have a filter before the carb inlet.
Car: 1982 Trans am
Engine: 383
I put the regulator in today, It runs a lot better now, It ran out of gas before I had chance to drive it.
Plugs, it always reeks like gas, big clouds of black smoke out the exhaust
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
