cold startup
Old Oct 7, 2008 | 07:46 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
cold startup
is there any way to make my engine more friendly in cold situations? right now it needs a solid 5 mins of warming before itll idle without dying, and thats with the idle set a tad too high.
Old Oct 7, 2008 | 07:57 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: cold startup
do you have a choke?
Old Oct 7, 2008 | 10:47 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Re: cold startup
yes i do.
Old Oct 7, 2008 | 10:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cold startup
Does it work?
Old Oct 7, 2008 | 11:04 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Re: cold startup
Originally Posted by Apeiron
Does it work?
yes, it does. would making it close later help?
Old Oct 7, 2008 | 11:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What kind of carb?
What kind of air cleaner?
What modifications? (intake, cam, exhaust, etc.)
Old Oct 8, 2008 | 12:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: cold startup
you have a '70GTO with a nortstar engine?? Now that's sacrilege!
If it's the stock q-jet, verify the choke is working right. If so, check the 3 choke settings.
Now that it's coming into fall again, I think we're going to be hit with the standard plethora of choke tuning questions... I'll have to dig up my one post where I explained them all with pictures...
Old Oct 8, 2008 | 07:09 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Re: cold startup
street avenger 770. K&N Filter, mildish cam .480 lift, not sure on duration, headers, new heads: 210cc runners 64cc chambers, performer RPM intake.
and the GTO, it was that or the caddy 500, and i wanted to drive it all over.
Old Oct 8, 2008 | 09:55 PM
Re: cold startup
what he said
Old Oct 8, 2008 | 09:57 PM
five7kid's Avatar
What distributor? Where's the timing set?
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
IROCtometal
Sep 9, 2015 10:01 AM
