Speed Demon too small for 242/248?
Old Oct 31, 2008 | 01:29 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I bought a Speed Demon last year for my 230/236 @ .050 cam and now stepped up to a 242/248 @ .050.
It is supposedly only rated for cams with 240 @ .050...how much is this hurting me and how difficult is this going to be to tune?
I am fairly new to carbs.
Old Oct 31, 2008 | 07:35 PM
Damon's Avatar
Re: Speed Demon too small for 242/248?
Is that the 670 CFM version? If so, yeah, it's a bit too small for a big cammed 383. BUT, it's nothing to jump off a bridge over. And certainly nothing you want to spend multiple hundreds of dollars on to upgrade to a carb that flows 100-150 CFM more. The power difference won't be that dramatic.
I say run what you got. Doesn't matter what carb you start with, it's going to require some tuning if you want it to run it's best.
Old Oct 31, 2008 | 09:12 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
No its a 750 DP but Demon advertises the Speed at 240 degrees @ .050 for some reason. I'm assuming it has to do with the metering blocks but am unsure.
It may turn into a total PITA to tune it correctly.
Old Nov 1, 2008 | 01:40 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it'll be fine to tune, probably just going to need to adjust the idle/high speed air bleeds and do some general jet changes, perhaps just paying to have the car wideband dyno tuned and let them make the adjustments would be best if you are unsure of how to proceed. Perhaps go buy a book on tuning holleys or go to a local library and take it out for a while.
Old Nov 2, 2008 | 08:48 AM
irocz436's Avatar
Car: 87 irocz
Engine: 436 chevy sbc
Transmission: th 400
Axle/Gears: 373
that should be more than enough carb i ran 750 holley when i dynoed my 436 chevy made 595hp/645ftlbs tq. just be patient and get it tuned properly.
Old Nov 2, 2008 | 12:59 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
xpndbl3...I sure hope it works out. While I don't want a choke horn on my carb (the Mighty Demon comes without one) I don't want to have to buy a new carb at the moment.
irocz436...I am confident the CFM rating is more than adequate (even too big depending on who you talk to) I am worried why Demon advertises this as only good to 240 duration.
I guess some serious trial and error will be in store for me!
Old Nov 2, 2008 | 07:45 PM
xpndbl3's Avatar
Car: 1984 Z28
that carb is MORE than sufficient, go grab a "good" holley tuning book and you'll be fine.
Old Nov 2, 2008 | 08:47 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks for the advise.
Can anyone explain to me the reason a carb would be listed for a specific duration? (Briefly of course, I still need to do some reading)
Old Nov 2, 2008 | 10:24 PM
xpndbl3's Avatar
Car: 1984 Z28
it's PV rating, the idle/high speed air bleeds, the idle restrictors, etc etc. no different than a marketing gimmick.
Old Nov 2, 2008 | 10:58 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks for the info!!
jhawkeye
May 25, 2022 06:33 PM
New2Chevy
Oct 4, 2015 11:27 PM
3tas4me
Sep 4, 2015 01:45 PM
InfinityShade
Aug 22, 2015 08:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
