tps adjustment screw
Old Apr 21, 2009 | 05:22 PM
sheardog's Avatar
Car: 1987 camaro
Engine: 5.0 ccc q-jet
i recently rebuilt my e4me ccc-qjet and while placing the airhorn i broke the plunger on the tps, i have replaced the tps but now the car runs rough and wants to stall after its warm enough to open the choke. do i need to adjust the screw under the plug or should the factory setting still be correct since i did not change the airhorn?
Old Apr 21, 2009 | 06:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You are setting the carb and TPS to each other. So, you need to check the voltage and adjust accordingly.
Old Apr 23, 2009 | 03:53 AM
sheardog's Avatar
Car: 1987 camaro
Re: tps adjustment screw
thank you sir i will check the thread for rebuild and get the correct voltage reading then see what i get on the tps.
Old Apr 23, 2009 | 06:28 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
1. Set timing
2. Set TPS for 0.40 (as close as you can) volts at idle
3. Adjust idle mixture screws and Idle Air Bleed for 50% duty cycle on Mixture Control Solenoid.
Let us know if the TPS adjustment fixes it. May have a little fine tuning to do on the carb rebuild.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86IROC112
Nov 27, 2015 09:54 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
greenyone
Sep 8, 2015 08:41 PM
lakeffect2
Sep 7, 2015 03:52 PM
