Iroc-Z with a Six Pack??? What do u think of a 3x2 carb setup for a 5.9L?
Old Nov 18, 2009 | 07:06 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
I wanna do something a little different with my camaro's motor so im think of doin a 3x2 (six pack) carb setup. The motor as of now just has a 6,000 rpm cam but im getting RHS pro action heads and now im thinking of adding a 3x2 setup to it.
What do u guys think? Does a 3x2 setup have better fuel delivery because of its design? Will it support higher rpms? Is it too many cfms for a 60 over 350?
Old Nov 18, 2009 | 07:14 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Re: Iroc-Z with a Six Pack??? What do u think of a 3x2 carb setup for a 5.9L?
nvm i dont think it will work with an HEI.... : (
I dont really wanna sacrafise my Digital HEI Streetfire Dizzy...
(if ur interested in buying a Streetfire Dizzy with a Digital HEI module with an adjustable rev limiter then let me know.)
Old Nov 18, 2009 | 08:19 PM
RU1NER's Avatar
Sounded like a cool idea maybe this one would work.
http://www.summitracing.com/parts/OFY-5254/
Old Nov 20, 2009 | 02:42 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
i dont think any tri power or three deuce setups work with an HEI
Old Nov 20, 2009 | 06:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its all for looks anyway, the typical reason multiple carbs were/are ever used was because the engines need more carburetion than was available in a single carb. In most cases, you will loose power with a multi carb setup.
Old Nov 20, 2009 | 09:24 PM
Wild Weasel's Avatar
Car: 1989 RS Drop-Top
Engine: 305 TBI
Try telling that to an owner of a GTO 389 tri-power or a 427 tri powered vette or maybe a 340 6pak or 2x4 409 or maybe even a (gasp) 426 Hemi.
Usually the problem with multi carbs is setting them up right. 3-2s are nice because you can run on the center carb if you can keep your foot out of the other two.
Old Nov 25, 2009 | 08:43 AM
Project-RS's Avatar
im running a edelbrock street tunnel ram on my camaro. not many of these setups around me so i did it. im not sure if theres much difference in hei distributers. i had to get a small cap style for fitment reasons. ill do some research and get back to you. cool idea also. i would like to see it happen
Old Nov 25, 2009 | 11:44 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
I confused, is it because there is no room for both the carbs and hei cap/distributor
Old Nov 25, 2009 | 03:41 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Some of my Dodge buddies have the three dueces on their car - it's for show only as they are close to impossible to setup 100% correct. It might look cool, but 1,100+ CFM is overkill for a street car.
Old Nov 25, 2009 | 04:05 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
yuppers, rear carb is back too far for an OEM style large HEI cap. Three deuces will perform well, though a properly done 4 bbl or EFI would probably outperform it..... But in the looks department, tough to beat a tri-power!!!! Trick to tuning them is a sync gauge, find a motorcycle shop that does 4 cylinder bikes, they'll have one....
Old Nov 30, 2009 | 08:14 AM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
im still looking into it. It all depends on if the right deals come around : P
Old Nov 30, 2009 | 09:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Would work with an MSD Pro-Billet distributor... just saying...
I'd go with dual 4's before three 2's though. But thats just me.
pimp2303
Jul 27, 2017 02:03 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
3rdgenparts
Aug 5, 2015 11:57 PM
