plenum for carb
Old Jan 9, 2010 | 10:22 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
plenum for carb
I want to use the duel setup tpi plenum air duct for a carb. Does anyone know what I could use for the hat? I want to use my stock hood so it would have to be low profile I think. Thanks for your help.
Old Jan 9, 2010 | 10:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: plenum for carb
You'd have to fab something - eve the Spectre carb hats and the Caddy hats won't fit under the stock hood - everything is 3 inches or higher and you've only got about 2 inches depending on the intake.
Old Jan 10, 2010 | 04:07 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
Re: plenum for carb
no your not right.
i just have buyes the low profile plenum from spectre!
if i`m right it will fit under the stock iroc-z hood
it is just 2.4 inch high! look at the picture.
Old Jan 10, 2010 | 08:32 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: plenum for carb
That might would work but, I want to use the duel air filters that came stock but need to connect to a carb instead of tuned port plenum. I guess I worded the opening post wrong. Sorry.
Old Jan 10, 2010 | 09:36 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: plenum for carb
here is one i found would this be what you are looking for. i believe it is made by turbonetics
Old Jan 10, 2010 | 09:46 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: plenum for carb
That is something like I am looking for . Thanks I will google it up.
Old Jan 10, 2010 | 09:49 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: plenum for carb
here is a link for ya where i found it.
http://www.vecco.com/products.php?sub_cat_id=30
Old Jan 11, 2010 | 01:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Spectre makes a low profile single as well.
http://www.spectreperformance.com/#CATALOG.98499
Old Jan 13, 2010 | 09:18 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: plenum for carb
Thanks guys that is the type plenum I was looking for.
Old Jan 14, 2010 | 04:41 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: plenum for carb
I'm getting ready to do the same thing...keep us posted on how it works out for you!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
sreZ28
Oct 22, 2015 08:21 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
