Timing clarification LG4
Old Mar 16, 2010 | 02:52 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Delete
Old Mar 16, 2010 | 03:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The procedure you outlined is correct, except for an '87 it should be a single tan wire to disconnect. Leave the transmission in park. 500 vs. 650 RPMs doesn't make that much difference, but don't let it get much higher than that (it probably won't).
When reconnected, the timing will be advanced from where you set it.
Old Mar 16, 2010 | 03:48 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: Timing clarification LG4
Im pretty sure mines a 4 pin connector. I think maybe its one of the earlier produced 87's
Old Mar 16, 2010 | 04:07 PM
five7kid's Avatar
Interesting. Large cap distributor with the coil in the cap?
Well, if that's what it is, that's what you do.
Old Mar 16, 2010 | 05:00 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 16, 2010 | 05:25 PM
five7kid's Avatar
That's a small cap distributor, which should be the single wire. At least, I've never heard of anything else.
Which connector did you disconnect?
Wouldn't be the first time the documentation/decals didn't catch up to the hardware.
Old Mar 16, 2010 | 05:44 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 17, 2010 | 04:50 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 17, 2010 | 10:28 AM
five7kid's Avatar
Any chance you could get a better picture of the 4-wire connector you disconnected?
If it affected the timing, it must be the right one.
Old Mar 17, 2010 | 01:59 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 17, 2010 | 05:33 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 21, 2010 | 07:37 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 21, 2010 | 07:52 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I have an 87 that used to have an LG4. The 4 wire connector is the correct one to unplug. There is no single tan wire. To be sure, the coil is mounted directly in front of the dizzy and has a plug wire that goes from it to the center of the dizzy. The mark on the damper will not be visible if the 4 wire connector is connected, but when disconnected it will move down to the visible area. Setting timing to arouynd 5* advance worked best for me. There are 2 plugs at the base of the dizzy make sure to disconnect only the 4 wire (closer to the firewall) if you disconnect the other one, car will turn off.
87cam305
Nov 17, 2015 06:30 PM
KNIGHTE
Jun 9, 2015 08:44 PM
road agent
Aug 5, 2007 11:17 PM
cool84
Apr 16, 2007 01:12 AM
87Formula356
Dec 8, 2003 11:22 PM
