Leaking 650cfm Quick Fuel
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
My Quick Fuel 650DP is somehow draining both bowls over a few weeks time period. The fuel is going into the intake and down into the oil pan because my oil level keeps getting higher. I know its not coolant because the oil is still black. What could cause the bowls to drain like that?
Car: 1991 Camaro RS
Engine: 355
Re: Leaking 650cfm Quick Fuel
Anyone? I replaced the metering block gaskets and still same issue. It will drain regardless of whether the engine is hot or cold so that eliminates boiling fuel.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
a high float level can cause it. fuel leaking past the power valve, or clogged air bleed can cause a siphon effect inside the carb with the engine off.
Car: 1991 Camaro RS
Engine: 355
If I just turn the key on and fill the bowls, they will drain even if I don't crank the engine so I'm a little baffled.
Car: 1991 Camaro RS
Engine: 355
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
sorry this is off way topic. how would the fuel get into the oil? that would be my concern.
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
That is strange. I would start by looking for a crack in the metering block. And maybe replace all the gaskets on it. or just do a complete rebuild, kits cant be all that much.
Car: 1991 Camaro RS
Engine: 355
Here is an update. I pulled the carb and set it on my bench. Best I can tell the fuel (slow leak) is leaking through a screw on the bottom of the base plate that goes into the main body. It's a slow leak because I can't ever see any wet spots on the bench. It takes about a week or two to empty the bowls.
