How much smoke is normal on a pcv valve??
Old Mar 24, 2010 | 12:03 AM
streetheatz28's Avatar
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
My 87 gta has been swapped to a carb setup its got a 600 holley 4 bbl. The pcv vaccum line is hooked up to the pass side valve cover and the breather is on the other side. Is that the correct way to hook it up? The breather smokes alot more than I'd think it should. The engine has 144k miles but I'm thinking the guy had nitrous on it considering there was a jegs gauge in the car that read 0-1500 psi and i'm hoping its not blow-by. How much smoke is normal and which way is the correct way to hook it up?
Thanks for the info.
Old Mar 24, 2010 | 12:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How much smoke is normal on a pcv valve??
The setup is normal, the smoke is not.
Old Mar 24, 2010 | 12:40 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
is your breather black and beginning to ooze? looks like you could be for a rebuild sooner than later...
Old Mar 24, 2010 | 12:41 AM
Engine: forged 355
Transmission: th350
Thanks for the quick reply! I didn't know if anyone was up this late. I guess i'll be doing a compression check tomorrow. The guy said the car ran 8.50's in the 8th and its pretty much stock. I thought he was just b/sing but I guess it ran that with a 100-125 shot
Old Mar 24, 2010 | 12:43 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
yeah if he didn't build his engine around the fact that he'd be running nitrous, he may have fried it...
Old Mar 24, 2010 | 12:56 AM
Engine: forged 355
Transmission: th350
Shouldn't the car be smoking out of the exhaust if it had excessive blow-by? Theres an exhaust leak because it still has the emissions exhaust manifolds on it but besides that it runs/sounds strong. If I have to rebuild its getting a lsx
Old Mar 24, 2010 | 12:58 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
when I had blowby on my car, I don't remember excess smoke out the tailpipe... I believe you'd get smoke if your heads were shot or if it was running rich... my car is carb'd and oil would pool in the air filter assembly...
Old Mar 24, 2010 | 09:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Blow-by means the gas is escaping around the rings into the crankcase instead of going into the exhaust.
Old Mar 25, 2010 | 03:33 PM
Engine: forged 355
Transmission: th350
Ok that makes sence. The piston walls/rings are worn enough to let gas pas by but not enough so that it lets oil by. I let it run for a little while today and it didn't smoke but a little out of the valve cover breather. I might switch the pcv to the other side and see if that helps. The motor still needs a rebuild but I'd like to drive it until I get the money to rebuilt it the way I want. Thanks for all the info guys.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Accerrito22
Sep 5, 2015 09:34 PM
