Carb leaking
Old Apr 3, 2010 | 06:56 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Carb leaking
Im having trouble with my carb when i turn the fuel pump on it doesnt hold the pressure i have it set to 8psi now...im not quite sure what it was at maybe thats what caused the problem im not quite sure but the fuel appears to be leaking out of the carb through these holes on the base plate and on all the outside holes on the carb itself ( i have a woodscrew pointing towards the holes in which the fuel appears to be coming out of) any help from you guys would be appreciated...i just would like to know what the holes are for and how to fix it so i can get back on the road thanksName:  Picture010.jpg
Old Apr 3, 2010 | 07:01 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: Carb leaking
the gas is coming out from the same hole in all four cornersName:  Picture011.jpg
Old Apr 3, 2010 | 10:17 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Carb leaking
that is your idle circuit. the fuel pressure needs to be 6-7psi. 8psi can cause flooding and fuel leaking where it shouldn't be.
Old Apr 4, 2010 | 10:31 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: Carb leaking
ok cool ill turn it down then so what do i need to fix this now or will it stop leaking when i turn it down
Old Apr 5, 2010 | 02:47 AM
Re: Carb leaking
i would also replace the metering block gaskets and power valve. those can also cause that. might as well install a whole renew kit.
Old Apr 5, 2010 | 09:20 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: Carb leaking
ok cool thanks alot
Old Apr 5, 2010 | 01:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only way fuel could be leaking from those holes is if the gasket is messed up or missing.
Old Apr 5, 2010 | 01:58 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: Carb leaking
ok you see i took it apart and the gaskets seem to be fine but ill just have to replace them anyways...are you talking the metering block gaskets?
Old Apr 5, 2010 | 02:29 PM
five7kid's Avatar
I'm talking about the throttle plate to main body gasket. Your pics have those deck screws (I cringe every time I see that pic with those screws in the throttle plate holes) pointing at the throttle plate and main body.
Old Apr 6, 2010 | 08:28 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: Carb leaking
ok cool haha i just set them in there i swear lol
Old Apr 6, 2010 | 12:07 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Re: Carb leaking
Turn the fuel pressure down and replace the metering block gaskets.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
makaveli09
Sep 15, 2015 10:43 AM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
