broken carburetor stem
Old May 31, 2010 | 02:38 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Transmission: 5 speed
Hi, got a question about my carb, did not find any answer on the forum, i have an 84 z28 HO, and the carb stem broke off, it lifts completely out of the carburetor, what would be the option to repair that? any help would be appreciated, thanks.
Old May 31, 2010 | 03:43 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: broken carburetor stem
if that picture is of your carb and stem it doesnt look broken but rather unscrewed, if there is a piece of the stem that is broken off you will need to disassemble your carb to extract the broken piece from the bottom of the main body then retap the threads to clean them up and get a new stem after reassembling the carb.
Old Jun 1, 2010 | 01:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it "lifts out", meaning it won't screw into the air horn, the option is to helicoil the main body. The carb should be disassembled when this is done.
Old Jun 1, 2010 | 02:25 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Jb weld enough said
Old Jun 1, 2010 | 06:24 PM
five7kid's Avatar
Originally Posted by Blown84Bird
Jb weld enough said
Never to be rebuilt again. . .
Don't be stupid. Fix it properly.
Old Jun 1, 2010 | 09:08 PM
X2
Old Jun 1, 2010 | 11:25 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Hey, thanks for all the quick response, that stem will not screw back in, and i try the jb weld with no luck. A friend of mine thinks that stem is attach to the carb bowl itself, if thats true, i should be looking for another quadraejet outer body (carb body) and rebuilt the carb again, am i correct with that assumption? Thanks.
Old Jun 2, 2010 | 01:07 PM
five7kid's Avatar
The air cleaner mount stud screws into the main body, correct.
Take the carb apart, then take the main body and stud to a machine shop. They should be able to helicoil the main body, using the stud to determine the correct thread size and type.
You could also send it to any number of shops that do mail order business, such as Jet http://www.jetchip.com/Shop/shopdisp...ppp=10&catID=2 or Carbs Unlimited http://www.carburetion.com/index.htm .
Or, you could look for another carb and rebuild it, or buy a rebuilt carb.
Old Jun 2, 2010 | 01:28 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Thanks Five7 for all the responses, I will try to take it apart and see if they can helicoil it, if not then I will see if they can rebuild it or replace it. Thanks again.
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
