Edelbrock leaking fuel?
Old Dec 8, 2010 | 09:02 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I installed a used but fairly new 750 edelbrock on my new engine. I am only able to work on it on the weekends. It has the stock electric fuel pump in tank, and a mallory fuel regulator. When I try to crank it for the first time each week, it has to prime for several revolutions. The needle on the fuel pressure gauge bounces erratic until I get the engine cranked, after that it,s steady, I dont find any fuel leaks and thought that the gas in the carb should last at least a week in the carb, since the temp is below 80*. Is this normal?
Old Dec 11, 2010 | 08:37 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Re: Edelbrock leaking fuel?
my car does the same thing, when i don't run the car for a few weeks,,it will take quite a few cranks to get it started, i have a 1405 edelbrock..if i run it weekly , it won't need cranking as much and start up quickly,, it did this also when i had the holley carb on it before i switched to the edelbrock.
Old Dec 11, 2010 | 04:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The volatile compounds in the gasoline evaporate out of the bowl when it sits.
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
