84 Camaro Running Rich
Old Mar 19, 2011 | 11:38 AM
Eclipsegs621's Avatar
Car: 84 Camaro
I have an 84 camaro with the 305. I am getting black smoke from the tail pipe on idle. I believe it is running rich because it wastes too much gas. The choke is stuck closed. Any ideas on how to adjust it to make it open? It has an electronic choke. I have to constantly mess with the throttle adjust screw on the driver side of the carb. I'm kind of new to carbs can anyone help?
Old Mar 20, 2011 | 04:26 AM
DoubleV's Avatar
Re: 84 Camaro Running Rich
Are you getting power to the choke coil? Is the wire even connected? Is the linkage hooked up?
Old Mar 20, 2011 | 07:38 AM
Car: 84 Camaro
Choke coil is getting power and all the linkage is there and working properly. Wire is connected. Had the alternator tested and is putting out plenty of power.
Old Mar 20, 2011 | 07:57 AM
DoubleV's Avatar
Can you can open the choke manually? If so, does it seem to have some tension on it and snap back shut when you let it go? If you're getting power TO the choke, maybe the actual choke element is bad.
Did this problem suddenly occure, or was it always like this?
Old Mar 20, 2011 | 08:05 AM
Car: 84 Camaro
The choke moves fine without any tension like there is'nt even a spring there. This problem has been there for about 4 months that i know of since i bought the car. I was trying to get it on the road and inspected this weekend. also i noticed that the transmission is shifting at 2000 rpm and the car doesn't go more than 15mph and that the brake pedal is hard to push as if the car was off. I'm thinking vacuum leak. and the transmission and brake is sudden it just happened yesterday.
Old Mar 20, 2011 | 08:09 AM
Car: 84 Camaro
So that I know that I'm getting this right. I'm new to carbs, The small butterfly in the front is the choke and the one on the bottom of the small one is the throttle plate correct?
Old Mar 20, 2011 | 11:53 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
yep
Old Mar 20, 2011 | 12:20 PM
Car: 84 Camaro
I have determine items a vacuum problem but
Not
Sure where to start. Any ideas?
Old Mar 20, 2011 | 01:52 PM
Car: 84 Camaro
Does anyone know or have a diagram for the vacuum system on the car that might be able to help me figure out where the leak is coming from?
Old Mar 20, 2011 | 08:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's possible the choke thermostat was put on incorrectly so the spring isn't contacting the lever inside the choke thermostat housing like it is supposed to.
also i noticed that the transmission is shifting at 2000 rpm ...
You probably need to adjust the throttle valve cable properly.
...and the car doesn't go more than 15mph and that the brake pedal is hard to push as if the car was off. I'm thinking vacuum leak. and the transmission and brake is sudden it just happened yesterday.
Check the vacuum line that goes between the brake booster and the back of the carb. Part of it is rubber, part is steel tube.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
squiggy2
Aug 9, 2015 09:30 PM
